I have another question, can I still create lens without "import Part"?thyssentishman wrote: ↑Mon Jul 04, 2022 7:16 am
No problem glad I could help. If there is nothing else you need, please make sure to mark the topic as solved by editing the title of your first post and prepending [Solved].
Good luck!
Kind regards,
Johannes
[Solved]:How to create a convex lens
Re: Question:How to create a convex lens
Freecad novice, A Python enthusiast
I don't know exactly what you mean. I suppose there are a lot of ways to achieve the same result and you are not necessarily bound to use the Part module.
As for using the scripts I sent you without the import Part line, I believe these will only work if the module was already imported in the FreeCAD session. I think this is done for example when you first load the Part or Part Design WB either manually or if they are auto-loaded on startup.
Kind regards,
Johannes
EDIT: Corrected minor spelling mistakes
Thanks for your help, I think I get what you mean.thyssentishman wrote: ↑Mon Jul 04, 2022 8:19 amI don't know exactly what you mean. I suppose there are a lot of ways to achieve the same result and you are not necessarily bound to use the Part module.
Kind regards,
Johannes
