Remove Internal Lines from Sketch
makafaka
Post by makafaka »
I was wondering if there was a function that would remove lines that are inside a sketch. I am not looking for isInside() because the lines in question are part of the sketch. In other words, I need an automatic way of getting lines that form the outline of the sketch.
Example:
Here is the starting sketch
1. Image
The function would return the internal lines of the sketch or simply delete them.
2. Image
This would be the result.
3. Image
Is there an existing function or algorithm to do this?
My FreeCAD Info:
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Re: Remove Internal Lines from Sketch
Moved from Developers forum. You post there if you are yourself a developer.
TheMarkster
Post by TheMarkster »
Presuming the sketch contains multiple closed wires you could make each wire into its own face, then fuse the list of faces together, then refine the output (to remove extraneous edges), and take the OuterWire of the final face.
Select the sketch and press Ctrl+Shift+P. This opens the python console with a few variables created. shp is the shape of the sketch object.
#get the wires
wires = shp.Wires
#make the faces
faces = [Part.makeFace(w, "Part::FaceMakerCheese") for w in wires]
#fuse the faces
fusion = faces[0].fuse(faces[1:]) #fuses the first face to the remaining faces in the list
#note: above will fail if there is only one face, in which case just use faces[0] as the final_face below
#refine fusion object to remove extra edges
refined = fusion.removeSplitter()
final_face = refined.Face1
outer_wire = final_face.OuterWire
Part.show(outer_wire,"outer_wire")
test sketch
test sketch
Snip macro screenshot-a7cf62.png (9.86 KiB) Viewed 1018 times
outer wire object
outer wire object
Snip macro screenshot-a516c5.png (7.96 KiB) Viewed 1018 times
