Extract default preferences from ui file? Feasible or not?
Roy_043
Post by Roy_043 »
The ui files used for the preferences also contain default values. In the Draft WB we have the issue that there are sometimes inconsistencies between the default values in the ui files and those used elsewhere in the code. One way this might be solved is to extract the defaults from the ui files, but them in a dictionary and then reference that dictionary whenever a default value is required. Is this idea feasible?
onekk
Re: Extract default preferences from ui file? Feasible or not?
Post by onekk »
as ui files are text files, probably some regex or other parsers could be useful.
But probably you have to write them for scratch, or maybe searching for "qt ui files parsing"
https://github.com/ordovician/QtUIParser.jl
It seems to be an xml file, so probably standard python tools could be used.
Hope it helps
Carlo D.
- Various other stuffs.
Roy_043
Post by Roy_043 »
Thanks. Very early beginnings, but here is my code so far:
# Preferences ui files are stored in resource files.
# For the Draft Workbench: /Mod/Draft/Draft_rc.py
import Draft_rc
import PySide.QtCore as QtCore
import xml.etree.ElementTree as ET
fnm = ":/ui/preferences-draftsnap.ui"
# https://stackoverflow.com/questions/14750997/load-txt-file-from-resources-in-python
fd = QtCore.QFile(fnm)
if fd.open(QtCore.QIODevice.ReadOnly | QtCore.QFile.Text):
    text = QtCore.QTextStream(fd).readAll()
    fd.close()
# https://docs.python.org/3/library/xml.etree.elementtree.html
root = ET.fromstring(text)
pref_widgets = [wid for wid in root.iter('widget') if "Gui::Pref" in wid.attrib["class"]]
Roy_043
Post by Roy_043 »
I have a question regarding this. Where should I put this preferences dictionary to make it available for all code in the Draft and Arch workbenches?
Add it as a property to the FreeCAD module, the same as is done for the DraftWorkingPlane, perhaps?
if not hasattr(FreeCAD, "DraftWorkingPlane"):
    FreeCAD.DraftWorkingPlane = WorkingPlane.plane()
Roy_043
Post by Roy_043 »
FWIW the current code (still WIP):
import Draft_rc
# fnm = ":/ui/preferences-draft.ui"
# fnm = ":/ui/preferences-draftinterface.ui"
# fnm = ":/ui/preferences-draftsnap.ui"
# fnm = ":/ui/preferences-drafttexts.ui"
fnm = ":/ui/preferences-draftvisual.ui"
    str = QtCore.QTextStream(fd).readAll()
    fd.close()
root = ET.fromstring(str)
# pref_widgets = [wid for wid in root.iter('widget') if "Gui::Pref" in wid.attrib["class"]]
def pref_from_PrefCheckBox(widget):
    val = False
    for elem in list(widget):
        att_name = elem.attrib["name"]
        if att_name == "checked": # Can be missing.
            val = elem.find("bool").text == "true"
        elif att_name == "prefEntry":
            pref = elem.find("cstring").text
        elif att_name == "prefPath":
            path = elem.find("cstring").text
    return [pref, path, val]
def pref_from_PrefComboBox(widget):
    idx = 0
    vals = []
        if elem.tag == "property":
            if att_name == "currentIndex": # Can be missing.
                idx = int(elem.find("number").text)
        elif elem.tag == "item":
            val = list(elem)[0].find("string").text
            vals.append(val)
    return [pref, path, vals[idx]]
def pref_from_PrefSpinBox(widget):
    val = 0
        if att_name == "value": # Can be missing.
            val = int(elem.find("number").text)
def pref_from_PrefDoubleSpinBox(widget):
    val = 0.0
            val = float(elem.find("double").text)
def pref_from_PrefQuantitySpinBox(widget):
    val = "0"
        if att_name == "rawValue": # Not sure if this can be missing.
            val = elem.find("double").text.rstrip(".0")
        elif att_name == "unit":
            unit = elem.find("string").text
    return [pref, path, val + " " + unit]
def pref_from_PrefColorButton(widget):
        if att_name == "color":
            sub = list(elem)[0]
            r = int(sub.find("red").text)
            g = int(sub.find("green").text)
            b = int(sub.find("blue").text)
    val = (r << 24) + (g << 16) + (b << 8) + 255
def pref_from_PrefLineEdit(widget):
    val = None
        if att_name == "text":             # Can be missing.
            val = elem.find("string").text # If text is missing val will be None here.
    if val is None:
        val = ""
def pref_from_PrefFileChooser(widget):
    return [pref, path, ""]
i = 0
for widget in root.iter('widget'):
    att_class = widget.attrib["class"]
    if att_class == "Gui::PrefCheckBox":
        print(pref_from_PrefCheckBox(widget))
        i = i + 1
    elif att_class == "Gui::PrefComboBox":
        print(pref_from_PrefComboBox(widget))
        i = i + 1
    elif att_class == "Gui::PrefSpinBox":
        print(pref_from_PrefSpinBox(widget))
        i = i + 1
    elif att_class == "Gui::PrefDoubleSpinBox":
        print(pref_from_PrefDoubleSpinBox(widget))
        i = i + 1
    elif att_class == "Gui::PrefQuantitySpinBox":
        print(pref_from_PrefQuantitySpinBox(widget))
        i = i + 1
    elif att_class == "Gui::PrefColorButton":
        print(pref_from_PrefColorButton(widget))
        i = i + 1
    elif att_class == "Gui::PrefLineEdit":
        print(pref_from_PrefLineEdit(widget))
        i = i + 1
    elif att_class == "Gui::PrefFileChooser":
        print(pref_from_PrefFileChooser(widget))
        i = i + 1
print(i)
onekk
Post by onekk »
Roy_043 wrote: Wed Jul 06, 2022 8:50 am I have a question regarding this. Where should I put this preferences dictionary to make it available for all code in the Draft and Arch workbenches?
I have seen that if you set it in the InitGui it is spreaded all over FC.
Not surprisingly, as it is normal behaviour for Python, once I have done this:
1) I have set some "global" variables in the InitGui module, thinking there will be some "separation" between WB, so I have set something like WB_Name and sone it for two WB one real and one "test WB".
2) I have found that the second WB loaded will overwrite the WB_Name for the whole FC instance.
Probably this could be a way, or maybe making some WB wide "global variable module", in other work a module that contains all the variables that is imported in all other modules, say maybe using something similar to:
import draft_vars as draft_v
and then refers using:
draft_v.something
It usually works, and it is clear what is a "global module variable" and what is not.
But it is not "very polite" but it will not use globals and locals explicitly, that is generally considered "bad practice"
Hope it helps
Carlo D.
Roy_043
Post by Roy_043 »
Thanks. To keep things simple I have decided to use this:
https://docs.python.org/3/faq/programmi ... en-objects
# pref_default("Mod/Draft", "gridSpacing")
# pref_default("Mod/Arch", "WallHeight")
def pref_default(path, pref, pref_dict=pref_dictionary()):
    if path not in pref_dict.keys():
        return None
    elif pref not in pref_dict[path].keys():
        return None
    else:
        return pref_dict[path][pref]
Full code attached.
prefs.py
(7.68 KiB) Downloaded 8 times
onekk
Post by onekk »
Many Thanks, interesting reading, now I have to rewrite most of my code. :lol:
Regards
Carlo D.
