Square to round transition
edwilliams16
Re: Square to round transition
Post by edwilliams16 »
OK. It looks like I have to test with a fresh FreeCAD instance to be sure it's clean. I added a spreadsheet output to see how that worked.
"""Create rectangular to circular metal transitions
Author: Ed Williams (@edwilliams16)
Copyright: 2022
Licence: CC BY-NC-ND 4.0 IT
import numpy as np
import Part, Mesh, MeshPart
import math
import flatmesh
from PySide import QtGui, QtCore
import Spreadsheet
# UI Class definitions
class TransitionGuiClass(QtGui.QDialog):
    def __init__(self):
        super(TransitionGuiClass, self).__init__()
        self.initUI()
    def initUI(self):
        self.inches = True
        self.result = userCancelled
        # create our window
        # define window		xLoc,yLoc,xDim,yDim
        self.setGeometry(	250, 250, 400, 350)
        self.setWindowTitle("Rectangle to circle transition")
        self.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
        # create some Labels
        self.labelRectangle = QtGui.QLabel("        Rectangle", self)
        self.labelRectangle.setFont(QtGui.QFont("Times", 16, QtGui.QFont.Bold))
        self.labelRectangle.move(20, 20)
        self.labelLengthX = QtGui.QLabel("LengthX", self)
        self.labelLengthX.move(20, 55)
        self.labelLengthX.setFont('Courier') # set to a non-proportional font
        self.labelLengthY = QtGui.QLabel("LengthY", self)
        self.labelLengthY.move(20, 80)
        self.labelLengthY.setFont('Courier')
        self.labelCircle = QtGui.QLabel("        Circle", self)
        self.labelCircle.setFont(QtGui.QFont("Times", 16, QtGui.QFont.Bold))
        self.labelCircle.move(20, 110)
        self.labelRadius = QtGui.QLabel("Radius", self)
        self.labelRadius.move(20, 140)
        self.labelRadius.setFont('Courier')
        self.labelCenterXYZ = QtGui.QLabel("CenterXYZ", self)
        self.labelCenterXYZ.move(20, 170)
        self.labelCenterXYZ.setFont('Courier')
        self.labelRotAxis = QtGui.QLabel("Rot Axis", self)
        self.labelRotAxis.move(20, 200)
        self.labelRotAxis.setFont('Courier')
        self.labelRotAngle = QtGui.QLabel("Rot Angle", self)
        self.labelRotAngle.move(20, 230)
        self.labelRotAngle.setFont('Courier')
        self.noSegments = QtGui.QLabel("Number of Segments", self)
        self.noSegments.move(20, 260)
        self.noSegments.setFont('Courier')
        # set up lists for scale pop-up
        self.popupItems1 = ("inches","mm")
        # set up pop-up menu
        self.popup1 = QtGui.QComboBox(self)
        self.popup1.addItems(self.popupItems1)
        self.popup1.setCurrentIndex(self.popupItems1.index("inches"))
        self.popup1.activated[str].connect(self.onPopup1)
        self.popup1.move(210, 20)
        # numeric input fields
        self.lengthX = QtGui.QLineEdit(self)
        self.lengthX.setValidator(QtGui.QDoubleValidator())
        self.lengthX.setText("40.00")
        self.lengthX.setFixedWidth(70)
        self.lengthX.move(100, 50)
        self.lengthY = QtGui.QLineEdit(self)
        self.lengthY.setValidator(QtGui.QDoubleValidator())
        self.lengthY.setText("45.00")
        self.lengthY.setFixedWidth(70)
        self.lengthY.move(100, 75)
        self.radius = QtGui.QLineEdit(self)
        self.radius.setValidator(QtGui.QDoubleValidator())
        self.radius.setText("15.00")
        self.radius.setFixedWidth(70)
        self.radius.move(100, 135)
        self.centerX = QtGui.QLineEdit(self)
        self.centerX.setValidator(QtGui.QDoubleValidator())
        self.centerX.setText("0.0")
        self.centerX.setFixedWidth(70)
        self.centerX.move(100, 165)
        self.centerY = QtGui.QLineEdit(self)
        self.centerY.setValidator(QtGui.QDoubleValidator())
        self.centerY.setText("0.0")
        self.centerY.setFixedWidth(70)
        self.centerY.move(180, 165)
        self.centerZ = QtGui.QLineEdit(self)
        self.centerZ.setValidator(QtGui.QDoubleValidator())
        self.centerZ.setText("15.00")
        self.centerZ.setFixedWidth(70)
        self.centerZ.move(260, 165)
        self.axisX = QtGui.QLineEdit(self)
        self.axisX.setValidator(QtGui.QDoubleValidator())
        self.axisX.setText("1.0")
        self.axisX.setFixedWidth(70)
        self.axisX.move(100, 195)
        self.axisY = QtGui.QLineEdit(self)
        self.axisY.setValidator(QtGui.QDoubleValidator())
        self.axisY.setText("0.0")
        self.axisY.setFixedWidth(70)
        self.axisY.move(180, 195)
        self.axisZ = QtGui.QLineEdit(self)
        self.axisZ.setValidator(QtGui.QDoubleValidator())
        self.axisZ.setText("0.0")
        self.axisZ.setFixedWidth(70)
        self.axisZ.move(260, 195)
        self.angle = QtGui.QLineEdit(self)
        validator = QtGui.QDoubleValidator()
        #validator.setRange(-90, 90, 1)
        self.angle.setValidator(validator)
        self.angle.setText("0.0")
        self.angle.setFixedWidth(70)
        self.angle.move(100, 225)
        self.segments = QtGui.QLineEdit(self)
        self.segments.setText('8')
        self.segments.setValidator(QtGui.QIntValidator())
        self.segments.setFixedWidth(30)
        self.segments.move(180, 255)
        # cancel button
        cancelButton = QtGui.QPushButton('Cancel', self)
        cancelButton.clicked.connect(self.onCancel)
        cancelButton.setAutoDefault(True)
        cancelButton.move(150, 280)
        # OK button
        okButton = QtGui.QPushButton('OK', self)
        okButton.clicked.connect(self.onOk)
        okButton.move(260, 280)
        # now make the window visible
        self.show()
    def onPopup1(self, selectedText):
        if selectedText == 'mm':
            self.inches = False
        else:
            self.inches = True
    def onCancel(self):
        self.close()
    def onOk(self):
        self.result			= userOK
        self.close()
# Constant definitions
userCancelled = "Cancelled"
userOK = "OK"
# code ***********************************************************************************
def flattenMesh(obj):
    #https://github.com/FreeCAD/FreeCAD/blob/0d0bd1168bb96ded8dfe5ab3ca60588dec5d2949/src/Mod/MeshPart/Gui/MeshFlatteningCommand.py
    points = np.array([[i.x, i.y, i.z] for i in obj.Mesh.Points])
    faces = np.array([list(i) for i in  obj.Mesh.Topology[1]])
    flattener = flatmesh.FaceUnwrapper(points, faces)
    flattener.findFlatNodes(5, 0.95)
    boundaries = flattener.getFlatBoundaryNodes()
    wires = []
    for edge in boundaries:
        pi = Part.makePolygon([App.Vector(*node) for node in edge])
        wires.append(Part.Wire(pi))
    return wires
def makeTemplate(form):
    def printVertices(vs):
        App.Console.PrintMessage('Template Vertices\n')
        if useInches:
            App.Console.PrintMessage('Inch units\n')
        else:
            App.Console.PrintMessage('mm units\n')
        for i, v in enumerate(vs):
            App.Console.PrintMessage(f'{i}:  ({v.x:.2f},{v.y:.2f})\n')
    def spreadsheetVertices(vs):
        if useInches:
            ustr = ' in'
            scale = 25.4
        else:
            ustr = ' mm'
            scale = 1.0
        sheet = App.ActiveDocument.addObject("Spreadsheet::Sheet","TransitionSheet")
        sheet.set('A1','X'+ustr)
        sheet.set('B1','Y'+ustr)
        sheet.set('C1','LengthX'+ustr)
        sheet.set('D1', f'{rectX/scale}')
        sheet.set('C2','LengthY'+ustr)
        sheet.set('D2', f'{rectY/scale}')
        sheet.set('C3','Radius nom/adj'+ustr)
        sheet.set('D3', f'{radius/scale/adjust}')
        sheet.set('E3', f'{radius/scale}')
        sheet.set('C4', 'CenterXYZ' + ustr)
        sheet.set('D4', f'{xoffset/scale}')
        sheet.set('E4', f'{yoffset/scale}')
        sheet.set('F4', f'{height/scale}')
        sheet.set('C5', 'Rot AxisXYZ')
        sheet.set('D5', f'{circleRotationAxis.x}')
        sheet.set('E5', f'{circleRotationAxis.y}')
        sheet.set('F5', f'{circleRotationAxis.z}')
        sheet.set('C6', 'Rot Angle (deg)')
        sheet.set('D6', f'{circleRotationAngle}')
        sheet.set('C7', 'Number of Segments')
        sheet.set('D7', f'{nSides}')
            sheet.set(f'A{i+2}', f'{v.x:.2f}')
            sheet.set(f'B{i+2}', f'{v.y:.2f}')
    #end spreadsheetVertices
    if form.result==userOK:
        useInches = form.inches
        if useInches:
            scale = 25.4
        else:
            scale = 1.
        rectX = float(form.lengthX.text()) * scale
        rectY = float(form.lengthY.text()) * scale
        height = float(form.centerZ.text()) * scale
        xoffset = float(form.centerX.text()) * scale
        yoffset = float(form.centerY.text()) * scale
        radius = float(form.radius.text()) * scale
        circleRotationAngle = float(form.angle.text())
        circleRotationAxis = V3(float(form.axisX.text()), float(form.axisY.text()), float(form.axisZ.text()))
        nSides = int(form.segments.text())
        adjust = (math.pi/(4 * nSides * math.sin(math.pi/(4 * nSides)))) #correct perimeter discretization
        radius *= adjust
        eps =1e-6
        sV = [0.5*V3(*v) for v in [(rectX,0,0), (rectX, rectY, 0), (0, rectY, 0),(-rectX,rectY,0),
        (-rectX, 0, 0), (-rectX, -rectY, 0), (0, -rectY, 0), (rectX,-rectY, 0), (rectX*(1-eps),0,0)]]
        # sv[3]      sV[2]      sV[1]
        # sv[4]      O          sV[0], sv[8] seam
        # sv[5]     sV[6]       sV[7]
        # 4N-sided quarter circle
        thetas = [2 * math.pi * j/(4 * nSides) for j in range(4*nSides + 1)]
        thetas[-1] -= eps #seam
        #create and locate circle
        cV2 = [V3(radius * math.cos(t), radius * math.sin(t), 0) for t in thetas]
        pl = App.Placement(V3(xoffset, yoffset, height), App.Rotation(circleRotationAxis, circleRotationAngle))
        cV = [pl.multVec(v) for v in cV2]
        faceList = []
        for k in range(4):
            face = Part.Face(Part.makePolygon([sV[2*k], cV[nSides*k], sV[2*k + 1], sV[2*k]]))
            #Part.show(face)
            faceList.append(face)
            face = Part.Face(Part.makePolygon([sV[2*k + 1], cV[nSides*(k + 1)], sV[2*k + 2], sV[2*k + 1]]))
            #Part.show(face)
        for k in range(4):
            for j in range(nSides):
                f = Part.Face(Part.makePolygon([sV[2*k +1], cV[nSides*k +j], cV[nSides*k + j+1], sV[2*k +1]]))
                #Part.show(f)
                faceList.append(f)
        shell = Part.Shell(faceList)
        qshell = Part.show(shell, "QuarterShell")
        qshell.Visibility = False
        mesh = doc.addObject('Mesh::Feature','Mesh')
        mesh.Mesh=MeshPart.meshFromShape(Shape=shell, LinearDeflection=0.1, AngularDeflection=0.523599, Relative=False)
        mesh.Label="QuarterShell (Meshed)"
        wires = flattenMesh(mesh)
        doc.removeObject(mesh.Name)
        template = Part.show(wires[0], "Template") #only one outline here
        #change origin and orientation centering bottom edge along x-axis
        newOrigin = template.Shape.Vertexes[4].Point
        edgedir = template.Shape.Edges[3].Curve.Direction
        rot = App.Rotation(-edgedir, V3(),V3(0, 0, 1), 'XZY')
        template.Placement = App.Placement(newOrigin, rot).inverse()
        doc.recompute()
        templateVertices = [v.Point/scale for v in template.Shape.Vertexes]
        print(useInches)
        print(scale)
        printVertices(templateVertices)
        spreadsheetVertices(templateVertices)
    if form.result==userCancelled:
        pass
doc = App.ActiveDocument
V3 = App.Vector
#get inputs from Gui
form = TransitionGuiClass()
form.exec_()
makeTemplate(form)
johnwang
Post by johnwang »
Here is the first quarter, but the length of the bottom line of the FIRST BACK TRIANGLE is not right yet.
I changed the Height to 250 to make the drawing smaller.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
jfc4120
Post by jfc4120 »
@johnwang thanks, I definitely want to program fittings the way I am used to, because I still do not understand all of the other Mesh programming and things like that.
Right now being new I am happy working with wire and faces.
But @edwilliams16 did a wonderful job on his program. I have studied over but it will be a long time before I understand those things. I definitely appreciate both of you for assistance.
jfc4120
Post by jfc4120 »
@edwilliams16 your final looked good, probably mine was .09 off, due to I use polygon and you used true arc lengths. If for example I increase number to say 36 it would probably only be .01 or .02 off which is close.
In the previous version I only got the error <class 'NameError'>: name 'useInches' is not defined, but it still worked anyway.
johnwang
Post by johnwang »
jfc4120 wrote: Sat Jul 23, 2022 2:20 am @Right now being new I am happy working with wire and faces.
If you open my macro, you can see only line in used.
jfc4120
Post by jfc4120 »
@johnwang I have looked at it. I also have been working on my first python program:
https://forum.freecadweb.org/viewtopic.php?f=22&t=70474
I got to the point where I can figure the angle, but I haven't figured out how to draw them yet.
I had to go back and do radian to degree conversions.
What it does in the other basicad is:
Screenshot 2022-07-23 115149.png (7.33 KiB) Viewed 1076 times
edwilliams16
jfc4120 wrote: Sat Jul 23, 2022 5:24 am @edwilliams16 your final looked good, probably mine was .09 off, due to I use polygon and you used true arc lengths. If for example I increase number to say 36 it would probably only be .01 or .02 off which is close.
Just comment out the line
radius *= adjust
if you don't want the true arc length correction.
johnwang
Post by johnwang »
jfc4120 wrote: Sat Jul 23, 2022 4:52 pm What it does in the other basicad is:
It looks like a hand rail I drawed the other day.
johnwang
Post by johnwang »
I tried to print out all the points. Could you also output from your program, so I can compare which line is wrong. Thanks.
jfc4120
Post by jfc4120 »
Yes, I have been busy doing something but I will get to it as soon as possible, on mobile now.
Edit, here are dimensions, but inches used.
t1_compare.FCStd
(10.54 KiB) Downloaded 11 times
