[solved] setEdit (transform) with active icons? possible?
dprojects
Post by dprojects »
Is it possible to turn on the icons and make them active in setEdit (transform) mode?
IF you right click ad the object and choose the "transform" the toolbars icons go into non-active state, is it possible to make them active again?
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
dprojects
Re: setEdit (transform) with active icons? possible?
Post by dprojects »
I solved this with another way. I can set transform mode from tool and also I can drill holes from the tool. So I don't have to activate the icons. Now I can drill holes just by moving drill bit with tool arrows or manually by hand with the transform.
Thanks
Darek
