BSplines with X number of points from txt file
DZ_FC
Post by DZ_FC »
1.FreeCAD Info
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Curves 0.5.1
  * sheetmetal 0.2.50
2. Problem Description
I need to create a couple of BSplines on a plate. The coordinates of the B-Splies are imported from txt file. First, to keep it simple, I decided that every B-Spline would have only three points with X, Y, and Z coordinates. My code looks like that:
##### Start reading from a file
if (fname[0] != ""):
			f = open(fname[0], "r")
			for line in f :
				IsData = line.split(",")
				x_start1 =float(IsData[0])
				y_start1 = float(IsData[1])
				z_start1 =float(IsData[2])
				x_start2 =float(IsData[3])
				y_start2 = float(IsData[4])
				z_start2 =float(IsData[5])
				x_start3 =float(IsData[6])
				y_start3 = float(IsData[7])
				z_start3 =float(IsData[8])
				### Begin command Std_Workbench
				Gui.activateWorkbench("DraftWorkbench")
				### End command Std_Workbench
####### Creating Bspline
				import Draft
				points = [FreeCAD.Vector(x_start1, y_start1, z_start1), FreeCAD.Vector(x_start2, y_start2, z_start2), FreeCAD.Vector(x_start3, y_start3, z_start3)]
				spline = Draft.make_bspline(points, closed=False, face=True, support=None)
				Draft.autogroup(spline)
			App.getDocument('Unnamed').recompute()
######## End Code
And it works fine! Now I want to expand the code. The B-splines should include a couple (X number) of points. I know this should be done with some for loop, but I have no idea, how to put it inside the FreeCAD.Vector constructor. Any suggestions would be appreciated.
Ps. I have attached the whole working macro(with the B-Splines with 3 points each) The FCstd file, which the macro generates, and an example of the Input File. The Input file comes from an Abaqus Simulation and could contain a big number of points for the B-Spline. For this reason, my solution with x_start1,2,3 is not very practical.
inputBspline.txt
(218 Bytes) Downloaded 12 times
Bspline08.08.FCStd
(14.86 KiB) Downloaded 9 times
B-Splines.FCMacro
(7.75 KiB) Downloaded 10 times
Re: BSplines with X number of points from txt file
Hi and welcome to the forum!
Please add the missing information.
DZ_FC
Post by DZ_FC »
Sorry. :roll: I believe I hit enter, instead Shift+Enter after the first line(Or just click of submit?) and I post it without wanting to do so. Now the whole situation should be more clear.
onekk
Post by onekk »
use the </> icon to add code tags, plus the information required in the post IMPORTANT: near the top of this forum section.
Post message are here to stay so it is not a sin to edit a message.
Subsequent post have a limited "edit time" "delete time" but first post is always editable by OP (Original Poster).
Regards
Carlo D.
- Various other stuffs.
onekk wrote: Mon Aug 08, 2022 12:23 pm Post message are here to stay so it is not a sin to edit a message.
Very well said.
Subsequent post have a limited "edit time" but first post is always editable by OP (Original Poster).
You can always edit your own posts. If there is no subsequent post this will pass unrecognized, other users just see the edited post. If a subsequent ost exists, you will see a comment that the post was edited.
Using the code tags will keep the spaces, which is mandatory to understand Python code.
onekk
Post by onekk »
chrisb wrote: Mon Aug 08, 2022 12:51 pm ...
Sorry I have mistaken the delete X that is available for a limited time.
Regards
Carlo D.
DZ_FC
Post by DZ_FC »
I believe that my post matches all requirements from "IMPORTANT: Please...". I try to explain as clearly as possible the problem and give some context. If is it still unclear, please let me know and I will try to explain it further and/or in a different way.
Thanks for the bits of advice about formulating a clear and structured post!
onekk
Post by onekk »
DZ_FC wrote: Mon Aug 08, 2022 3:23 pm I believe that my post matches all requirements from "IMPORTANT: Please...".
Quite correct.
First part is slightly wrong.
the first part is missing so no indication of the os you used.
Regards
Carlo D.
edwilliams16
Post by edwilliams16 »
I assume you are looking for something like this
import Draft
f = open('/Users/ed/Downloads/inputBspline.txt', 'r')
#each line is one bspline x1, y1, z1, x2, y2, z2 ... xn, yn, zn
# n can vary, but there must be 3n floats in the line
for line in f:
    data = line.split(',')
    numdata = [float(field) for field in data]
    num2d = [App.Vector(numdata[i], numdata[i+1], numdata[i+2]) for i in range(0, len(numdata), 3)]
    spline = Draft.make_bspline(num2d, closed=False, face=False, support=None)
heda
Post by heda »
should be exactly same as edwilliams, just a bit different python constructs
not better, just putting the use of alternative code-constructs out there :-)
using zip in loops gives great code readability imho
import Draft
with open('/Users/ed/Downloads/inputBspline.txt', 'rt') as filehandle:
    lines = [line.strip() for line in filehandle.readlines() if line.strip()]
for line in lines:
    data = [float(field) for field in line.split(',')]
    num2d = [App.Vector(*xyz) for xyz in zip(data[0::3], data[1::3], data[2::3])]
