Can't draw simple rectangle qt
stefankorisnik3
Post by stefankorisnik3 »
I want to draw simple rectangle with qt. I'm using following code but no rectangle. Can you tell me what is wrong about this code?
from PySide import QtGui, QtCore
from PySide.QtGui import QPainter, QBrush, QPen
from PySide.QtGui import Qt
painter = QPainter(self)
painter.setPen(QPen(Qt.black, 5, Qt.SolidLine))
painter.setBrush(QBrush(Qt.green, Qt.DiagCrossPattern))
painter.drawRect(QtCore.QRect(0, 0, 50,50))
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CurvedShapes 1.0.3
  * Curves 0.5.2
Re: Can't draw simple rectangle qt
I'm sorry not being able to answer your question, but may I ask what you need such a rectangle for? It won't be available for modeling.
stefankorisnik3
For the GUI
wandererfan
Post by wandererfan »
stefankorisnik3 wrote: Thu Aug 11, 2022 8:39 pm I want to draw simple rectangle with qt. I'm using following code but no rectangle. Can you tell me what is wrong about this code?
Where do you expect to see your rectangle? You're drawing with an orphan painter.
This sort of code would normally be in the paint event of a custom widget that has been added to the main window or another higher level widget.
stefankorisnik3
On the GUI window.
wandererfan
stefankorisnik3 wrote: Fri Aug 12, 2022 2:17 am On the GUI window.
If you mean the 3d view, this isn't the way to do it. You'd want to use something like
import Draft
r = Draft.makeRectangle(100, 100)
r.recompute()
Do you mean to create a dialog on the fly and the rectangle should be some frame on it?
gbParametric
Post by gbParametric »
What do you mean by drawing a rectangle ?
Something like this ?
https://doc.qt.io/qt-6/qtwidgets-painti ... ample.html
edit (Added another link)
https://likegeeks.com/pyqt5-drawing-tutorial/
stefankorisnik3
Yes i meant to create a dialog on the fly and the rectangle should be some frame on it.
onekk
Post by onekk »
stefankorisnik3 wrote: Sat Aug 13, 2022 8:02 pm Yes i meant to create a dialog on the fly and the rectangle should be some frame on it.
It is not clear where you want to make the rectangle appear?
The extrapolate code you posted is using
and this usually say that is used in a Class, but a Widgest has to have a Parent, and generally to have them appear on the FC at least the container must be a a child of FC MainWindow, maybe a dilalog, maybe some other part of the interface.
Probably some Qt background is required, sadly Qt documentation is usually addressing C++, and PySide2 example are not very usual, so some guessing and try are required for non trivial things.
Plus use the Qt5 documentation as Qt6 is not implemented for now, and something has changed from Qt5 to Qt6 so better to stay on Qt5 for now if you are not used to Qt mechanics, that is not very linear sometimes.
Regards
Carlo D.
- Various other stuffs.
