STL export: objects end up in different locations - how to maintain origins?
0xCoto
Post by 0xCoto »
I have the following Python code which takes a STEP file and exports each object as a separate STL file. It also exports an STL containing everything ("model.stl"):
def step2stl(step_file="model.step", clear=True):
    doc = FreeCAD.newDocument("Unnamed")
    # Delete pre-existing STL files
    dir_name = "data"
    test = os.listdir(dir_name)
    for item in test:
        if item.endswith(".stl"):
            os.remove(os.path.join(dir_name, item))
    # Empty out tmp directory
    if clear:
        dir = "data/tmp"
        if os.path.exists(dir):
            shutil.rmtree(dir)
        os.makedirs(dir)
    # Import STEP file
    Import.insert("data/" + step_file, "Unnamed")
    obj_list = []
    for obj in FreeCAD.ActiveDocument.Objects:
        if hasattr(obj, "Shape"):
            obj_list.append(obj.Name)
    __objs__ = []
    for object in obj_list:
        __objs__.append(FreeCAD.getDocument("Unnamed").getObject(str(object)))
    Mesh.export(__objs__, "data/tmp/model.stl")
    del __objs__
        __objs__ = []
        if object.startswith("Part"):
        Mesh.export(__objs__, "data/" + str(object) + ".stl")
        del __objs__
However, in some cases like this one (STEP import):
There is a different origin associated with each object, and if I export each STL separately, and then import them one by one, I get this offset:
This happens with both the GUI fashion of importing and exporting, as well as the scripting way. Is there a way to tell FreeCAD to convert everything so that it uses a single global origin, so that my exported STL files remain intact (just like I nicely see it on FreeCAD's interface when I import the STEP file)?
jbi
Re: STL export: objects end up in different locations - how to maintain origins?
Post by jbi »
I think you have to transform the geometry
newbody=body.transformGeometry(body.Placement.toMatrix())
afterwards you can export this newbody.
Maybe transformShape is also working, but you have to check yourself (just check the Placement after transform, should be the origin)
onekk
Post by onekk »
Problem with STL is that is a triangulation (a shape made of triangles) so it is simply a bunch of vertexes that form the "shape".
You have two places that FC (FreeCAD) use to determine where to show your solid:
1) "Shape" property
2) "Placement" property
Probably the exporter use the Shape property.
You could consolidate both in "Shape" property use the advice above that will create a new solid.
Regards
Carlo D.
- Various other stuffs.
0xCoto
Post by 0xCoto »
jbi wrote: Sat Aug 13, 2022 8:37 am I think you have to transform the geometry
Thanks, I think I got the idea, but how exactly would I implement this transformation to the last part of the code? I tried a few ways but it seems like I need to handle the shape/part/object in a specific class/type?
# Import STEP file
# Export full model as a single STL
obj_list = []
    if str(obj) == "<Part::PartFeature>":
        obj_list.append(obj)
def getObj(object):
    return FreeCAD.getDocument("Unnamed").getObject(str(object.Name))
__objs__ = list(map(getObj, obj_list))
# Export each object as a separate STL
    if object.Name.startswith("Part"):
        ### I guess the transform should take place here somehow? ###
        obj = FreeCAD.getDocument("Unnamed").getObject(str(object.Name))
        Mesh.export([obj], "data/" + str(object.Name) + ".stl")
jbi
Post by jbi »
# Import STEP file
obj_list = []
def getObj(object):
    orig=FreeCAD.activeDocument().getObject(str(object.Name)) #changed to active document instead of FreeCAD.getDocument("Unnamed")
    transformed=orig.Shape.transformGeometry(orig.Placement.toMatrix())
    filename= "data/" + str(object.Name) + ".stl")
    transformed.exportStl(filename,0.1) #second parameter is deviation tolerance // don't know how to do it with Mesh.export()
I have changed the last few lines. But it is untested. If you need to use Mesh.export() someone else with deeper knowledge of the document objects should have a look.
Generally you make it for everybody far more interesting (and for you much more likely to get helped) if you provide a model with your post.
0xCoto
Post by 0xCoto »
jbi wrote: Sat Aug 13, 2022 5:52 pm I have changed the last few lines. But it is untested. If you need to use Mesh.export() someone else with deeper knowledge of the document objects should have a look.
I've attached the file (Wifi_Antenna.step). Looks like I'm getting the following error:
  File "/home/apostolos/Desktop/api/solver_api.py", line 990, in <module>
    step2stl(step_file, clear=clear)
  File "/home/apostolos/Desktop/api/solver_api.py", line 54, in step2stl
Part.OCCError: Geom_TrimmedCurve::parameters out of range
I also tested against a different model (attached, dipole.stp - which doesn't have any issues with multiple origins etc.), and this one seems to run, but it seems to have messed with the distances a bit.
Before (original model):
After running the script:
dipole.step
(13.64 KiB) Downloaded 19 times
Wifi_Antenna.step
(456.51 KiB) Downloaded 11 times
onekk
Post by onekk »
Your screenshot seems to reveal that some recomputing is missing from the first image (blue marks on the icons).
Plus I don't know if STL is supporting multiple objects per file, as usually a STL file will contain a single triangulation.
Regards
Carlo D.
0xCoto
Post by 0xCoto »
onekk wrote: Sat Aug 13, 2022 10:21 pm Your screenshot seems to reveal that some recomputing is missing from the first image (blue marks on the icons).
I simply created the two cylinders in FreeCAD, positioned them and exported the file as STEP. I re-opened, and the model looks fine (never really paid attention to the blue marks since most of my CAD processing and STL exporting has worked OK).
onekk wrote: Sat Aug 13, 2022 10:21 pm Plus I don't know if STL is supporting multiple objects per file, as usually a STL file will contain a single triangulation.
If you select all objects and use File -> Export -> STL, it creates an STL file containing both objects as a single "object"/triangulation:
Still not sure how to fix the origin problem though. :(
edwilliams16
Post by edwilliams16 »
When I opened your WiFi_antenna.step file:
1) There's a recomputing problem. It never comes to a final answer.
2) Body001 and Shell001 appear to be identical and both are shells, not solid objects.
It seems that should be fixed first.
