How to lock the navigation?
DorinDXN
Post by DorinDXN »
Hi all,
In long macros how I can disable navigation by scripting? (say, at the beginning of the macro)
to prevent accidental rotation or zoom or anything can be caused by keys or mouse if, by accident, gets focus,
as it will affect the .saveImage output.
thanks!
cheers,
Dorin
OS: Windows 10 and Windows 7
Version: 0.18.16078 (Git)
Hash: 67df9f3a828fbb0fec29d039792d4baf3d9ee8e0
Python version: 2.7.14
OCC version: 7.2.0
onekk
Re: How to lock the navigation?
Post by onekk »
DorinDXN wrote: Sat Aug 13, 2022 1:32 pm ...
as usual, what FC version are you using?
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
It may or not may be relevant, but as said many times here in this forum, there are many variables that could came into play like:
  • Qt Version
  • Python Version
  • Coin3D Version
So probably it is not a "pedantic request" to have some infos, eventually if you are using multiple version of FC you could post "in the first post" your relevant infos for every FC version you are using.
If a user came here say two or more years in future (using maybe forum search) things could have changed, so giving a proper "FC version info" could be useful.
Regards
Carlo D.
Edited Post to shorten it deleting "full quoting of OP"
- Various other stuffs.
onekk
Post by onekk »
DorinDXN wrote: Sat Aug 13, 2022 2:46 pm ...
Please add it to the first post and enclose it in code tags.
Plus, it is complicate to answer for a very old version as now the "stable" is 0.20.
Usually the answer is "install latest stable" which is 0.20 (for now, probably 0.20.1 will be out soon).
You could amend the post with the version putting maybe "deleted post" or "see first post" if you could not delete it with the X button.
Regards
Carlo D.
I have moved the FreeCAD infos and removed the separate post. Members can delete their own posts only as long as there is no answer to them.
DorinDXN
Post by DorinDXN »
Thanks.
My question wasn't for a particular FC version.
Appreciate any hint, regardless of the FC used.
For various tasks, I found solutions which were stated for FC 0.20 or 0.19
and I adapted eventually for FC 0.18 which I prefer to use.
cheers,
Dorin
DorinDXN wrote: Sun Aug 14, 2022 7:08 am My question wasn't for a particular FC version.
The questions aren't usually the problem. But often the answers are version dependent.
