Question continued from square to round
jfc4120
Post by jfc4120 »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Help 1.0.3
@johnwang
I don’t have a round to round; I have a general triangulation program.
You position as though you were inside duct looking at either direction of airflow or opposite.
And you set points on one end, then the other and it’s triangulated and laid out on another layer.
See images and I have captions explaining.
I am currently trying to do this code in freecad, but I am only on first section so far. I can't figure out how to rotate group to do another section.
Basiccad is easier to do things, you can do things like store a series of previous points.
Each new section triangulated starts at 0,0,0. In Basiccad you can reset origin. In python (Freecad) you are stuck with same origin, so it makes it harder.
Also see: https://forum.freecadweb.org/viewtopic. ... on#p611897
same code works on those. But some points have to be selected multiple times, depending on fitting (duct).
If you can figure out a rewrite that works in python that would be great.
Bottom line and top curve are drawn in separate, not part of the program.
johnwang
Re: Question continued from square to round
Post by johnwang »
I store a series of points like this:
X=[]
Y=[]
...other code
X.append(aValue)
Y.append(bValue)
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
onekk
Post by onekk »
The point is to take the workflow of the original program and make a python equivalent.
From what I know Python is more powerful than basic, and probably you could leverage even some function present in FC ta make things more easily.
As example you could determine intersections points of lines and other things simply invoking a method or obtain distance from two points (Vectors) dimply using an appropriate method.
All without using mathematical solutions but using geometrical solutions.
And many more.
Regards
Carlo D.
- Various other stuffs.
johnwang
Post by johnwang »
What is the value of SYS(1)?
and what the value of that point. There are SYS(1) of them.
FOR J = 1 TO SYS(1)
A = A + 1
CTR = CTR + 1
POINTVAL XA YA ZA A
AX(A) = XA
AY(A) = YA
AZ(A) = ZA
NEXT
jfc4120
Post by jfc4120 »
Sys 1 is the number of points currently set.
edwilliams16
Post by edwilliams16 »
johnwang
Post by johnwang »
jfc4120 wrote: Sun Aug 14, 2022 4:01 am Sys 1 is the number of points currently set.
So, need to select some points?
Then hard to test this code.
jfc4120
Post by jfc4120 »
@johnwang here is where I'm at so far in testing, I am at one section at a time. I am still trying to figure out the looping, rotating, etc like I did in Basiccad.
Code so far:
# -*- coding: utf-8 -*-
import FreeCAD, FreeCADGui
import Draft
import math
# from math import cos, sin, radians
from PySide import QtGui
convert = 25.4
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
def line_length(x1=0, y1=0, z1=0, length=10, angle=0):
    x2 = x1 + length * math.cos(math.radians(angle))
    y2 = y1 + length * math.sin(math.radians(angle))
    z2 = z1
    Draft.makeWire([Vector(x1, y1, z1), Vector(x2, y2, z2)])
def coord(x1=0, y1=0, z1=0, length=10, angle=0):
    #x2 = x2 * convert
    #y2 = y2 * convert
    z2 = z1
    #z2 = z2 * convert
    coo = [x2, y2, z2]
    return coo
# def coord(x1=0, y1=0, z1=0, length=10, angle=0):
#    x2 = x1 + length * math.cos(math.radians(angle))
#    y2 = y1 + length * math.sin(math.radians(angle))
#    z2 = z1
#    coo = [x2, y2]
#    return coo
start_point = Vector(0, 0, 0)
selX = FreeCADGui.Selection.getSelectionEx()
PrintMsg = FreeCAD.Console.PrintMessage
PrintMsg("Objects selected:\n")
KOUNT = 0
# added
for sel in selX:
    KOUNT = KOUNT + 1
    v = sel.Object.Shape
    X = v.Point.x * .039370078
    Y = v.Point.y * .039370078
    Z = v.Point.z * .039370078
    if KOUNT == 1:
        multlist = [[X, Y, Z]]
    if KOUNT > 1:
        multlist.append([X, Y, Z])
# added
YTMP = multlist[2][1]
print('ytmp', YTMP)
LINE02 = math.sqrt(((multlist[0][0] - multlist[2][0])) ** 2 + ((multlist[0][1] - multlist[2][1])) ** 2 + ((multlist[0][2] - multlist[2][2])) ** 2)
LINE12 = math.sqrt(((multlist[1][0] - multlist[2][0])) ** 2 + ((multlist[1][1] - multlist[2][1])) ** 2 + ((multlist[1][2] - multlist[2][2])) ** 2)
LINE01 = math.sqrt(((multlist[0][0] - multlist[1][0])) ** 2 + ((multlist[0][1] - multlist[1][1])) ** 2 + ((multlist[0][2] - multlist[1][2])) ** 2)
A1 = math.acos(((abs(LINE02) ** 2 + abs(LINE12) ** 2 - abs(LINE01) ** 2) / (2 * LINE02 * LINE12)))
# print('line01', LINE01)
A1 = A1 * (180 / 3.1459)
# print('A1', A1)
LINE32 = math.sqrt(((multlist[3][0] - multlist[2][0])) ** 2 + ((multlist[3][1] - multlist[2][1])) ** 2 + ((multlist[3][2] - multlist[2][2])) ** 2)
LINE13 = math.sqrt(((multlist[1][0] - multlist[3][0])) ** 2 + ((multlist[1][1] - multlist[3][1])) ** 2 + ((multlist[1][2] - multlist[3][2])) ** 2)
A2 = math.acos(((abs(LINE12) ** 2 + abs(LINE32) ** 2 - abs(LINE13) ** 2) / (2 * LINE12 * LINE32)))
A2 = A2 * (180 / 3.1459)
x1 = y1 = z1 = 0  # Edit coordinate origin
length = LINE02
length = length * 25.4
angle = 90
line_length(x1, y1, z1, length, angle)
clist1 = coord(x1, y1, z1, length, angle)
length = LINE12
angle = 90 + A1
clist2 = coord(x1, y1, z1, length, angle)
print('clist2x:', clist2[0])
length = LINE32
angle = 90 + A1 + A2
clist3 = coord(x1, y1, z1, length, angle)
print('clist3', clist3)
Draft.makeWire([Vector(clist2[0], clist2[1], clist2[2]), Vector(clist3[0], clist3[1], clist3[2])])
Eventually I need to figure out how to rotate just a group (Layer in designcad). Yes I know I can use mesh, but I want to triangulate. It's a hobby also converting basiccad to python. And fun. And hard also as python and freecad does things different.
And some images:
johnwang
Post by johnwang »
I like the other way. Just specify a few parameters, then draw the flat pattern directly. No need to draw the geometry and no need to select points.
jfc4120
Post by jfc4120 »
@johnwang I did the triangulation program in python. Needs some cleanup (many print statements) for testing Plus I am going to test more fittings.
All is laid out from inside fitting.
