Does importing too many classes (definitions) can make the execution much longer?
stefankorisnik3
Post by stefankorisnik3 »
Does importing too many classes (just declarations nothing executable) can make execution of FreeCAD python program much longer?
Re: Does importing too many classes (definitions) can make the execution much longer?
As soon as it is enough to need slower memory, e.g. swap space on a hard disc, it will make a program slower.
TheMarkster
Post by TheMarkster »
I don't think it matters so much in terms of execution time after all the imports are done, but I haven't tested it. You would need to do some profiling to see for sure. Obviously, the imports themselves will take some time to do, which can be quite noticeable if there are many packages to be imported. If all the packages are not needed every time the script is executed, then it can be sensible to do the imports only as needed rather than importing everything upon startup at the top of the source code.
