Having exceptions that cause loss of 3D rotation
freedman
Post by freedman »
I'm trying to use a slot to trigger my macro to do this "self.on_color_to_refacing()". It works for a while but then I get an Exception and my mouse won't rotate in the 3D. If I change mouse modes and back everything is fine once again, for a while. I don't know what to do now. I have tried many different slots and they all do the same thing. The code I'm calling takes seconds to process so that's probably bad. :) Anyone have ideas.....
The goal is to trigger after an object modification and I don't want to trigger on recomputes.
Thanks
Here is the exception:
09:23:13  Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Access violation
My code:
    def offset_control(self):
        if not self.no_update.isChecked():
            if self.latch == False:
                self.latch = True
                self.latch = False
    class DocObserver:
    	def slotCommitTransaction(self, logic):
        visCB.offset_control()
visCB = cbToolBox()
do = visCB.DocObserver()
App.addDocumentObserver(do)
Here is the slot info:
  /** Called when an observed document commits a transaction */
    void slotCommitTransaction(const App::Document& Doc);
mfro
Re: Having exceptions that cause loss of 3D rotation
Post by mfro »
freedman wrote: Tue Aug 16, 2022 4:43 pm... It works for a while but then I get an Exception and my mouse won't rotate in the 3D...
Something working for a while and later on an access error in Python suspiciously smells like the garbage collector is stealing away something you still require.
Cheers,
Markus
onekk
Post by onekk »
freedman wrote: Tue Aug 16, 2022 4:43 pm Here is the exception:
This resemble me some problems with Qt signals or slots, not properly managed.
But I'm not a Qt experts, try to search about Transactions, if I don0t remember wrong there are some consideration around made by some developers when someone was developing a WB that heavily use the mouse.
Sorry to not be more helpful.
Regards
Carlo D.
- Various other stuffs.
