How can I get the axis(x,y,z) of a object???
oscarchan
Post by oscarchan »
Hi guys!
I am using FC0.18.
I am trying to access the Axis data of a selected object. eg:I wanna get (-3.2,-0.22,4.4) in the case below.
But through the code
Gui.Selection.getSelection()[0].Placement.Rotation.Axis
I can't make it.
How do you guys get that infomation??? Thanks in advance!
Thank you!
Roy_043
Re: How can I get the axis(x,y,z) of a object???
Post by Roy_043 »
The rotation axis is returned as a unit vector. If you save and reopen the file the axis values will have been recalculated accordingly.
demonlibra
Post by demonlibra »
element = Gui.Selection.getSelection()[0]
position_x = element.Placement.Base[0]
position_y = element.Placement.Base[1]
position_z = element.Placement.Base[2]
rotation_x = element.Placement.Rotation.Axis.x
rotation_y = element.Placement.Rotation.Axis.y
rotation_z = element.Placement.Rotation.Axis.z
from math import *
rotation_angle = degrees(element.Placement.Rotation.Angle)
Founder
Post by wmayer »
Gui.Selection.getSelection()[0].Placement.Rotation.RawAxis
gives you the information as shown in the property editor
oscarchan
Post by oscarchan »
wmayer wrote: Wed Aug 17, 2022 11:15 am
Thanks I tried in FC0.20 it works but in FC0.18, it says 【AttributeError: 'Base.Rotation' object has no attribute 'RawAxis'】
Thank you!
oscarchan
Post by oscarchan »
@Roy_043 Thank you. It works like you mentioned.
@demonlibra Thank you!
Thank you!
oscarchan wrote: Thu Aug 18, 2022 1:05 am Thanks I tried in FC0.20 it works but in FC0.18, it says 【AttributeError: 'Base.Rotation' object has no attribute 'RawAxis'】
Is there a good reason to use 0.18?
Founder
Post by wmayer »
Oh, I missed that information. IIRC the attribute has been added with v0.19.
