[Solved] BSPlineCurve insert Knots question.
onekk
Post by onekk »
Trying to solve this problem, using scripting:
https://forum.freecadweb.org/viewtopic. ... 92#p618192
I've put together the code linked below.
I've inserted some knots, as it seems that the insertion is possible using already available methods insertKnot
bs0c.insertKnot(0.10)
bs0c.insertKnot(0.333333333333333)
bs0c.insertKnot(0.666666666666666)
bs0c.insertKnot(0.75)
I know it is rough but I wonder if there is a method to equally spacing points to avoid the bend of the curve.
What happens to poles?
Or better how to add control points to equally spaced along the curve?
Probably I'm not guessing something correct as I can't get to work the method removeKnot
20220816-bspline_addp.py
(3.92 KiB) Downloaded 35 times
Regards
Carlo D.
Edited to try to make the question and the title more clear
- Various other stuffs.
onekk
Re: BSPlineCurve insert Knots question.
Post by onekk »
Hoping to be more precise:
I have modified the code, to be more articulated, to show some data:
The above is a try to visualize the position of the knots on the curve.
But I've a doubt:
These are the knots of the "upper bspline" after having added some knots using insertKnots
bs0c Knots:  [0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0]
I visualize them using:
vtx = Part.Vertex(spline.value(knt))
Where knt is the knot obtained from the above "Knot vector"
is correct to assume that the value returned from the "Knot Vector" is the u parameter of Part.BSplineCurve.value()?
Regards
Carlo D.
onekk
Post by onekk »
Some more iterations and some simplified code:
Added a sort of polygon visualization, as seen on BSpline explanation.
Shortened the code to include only relevant bspline (limiting to one BSpline for clarity)
20220818-bspline_analysis.py
(4.02 KiB) Downloaded 30 times
Hoping this is correct.
In the meantime, I'm studying some CG text found on Accademia.edu, for which a subscriptions is needed
COMPUTER AIDED GEOMETRIC DESIGN - Thomas W. Sederberg - October 9, 2014
But is rather advanced for my math skills, see what happens and if my brain will not smoke. :-D
Regards
Carlo D.
Chris_G
Post by Chris_G »
onekk wrote: Wed Aug 17, 2022 5:26 pm Trying to solve this problem, using scripting:
I don't understand what you're trying the achieve by inserting knots ?
onekk wrote: Wed Aug 17, 2022 5:26 pm I know it is rough but I wonder if there is a method to equally spacing points to avoid the bend of the curve.
What points ? The points on curve corresponding to the knots ?
No. A knot is just a parameter in the parametric space of the curve.
A parameter has a corresponding 3D point image on the curve (Curve.value(u))
And a 3D point on the curve has a corresponding parameter in the parameter range (Curve.parameter(point))
You can get equally spaced points on curve with :
pts = curve.discretize(number_of_points)
And get back the corresponding parameters with:
params = [curve.parameter(p) for p in pts]
onekk wrote: Wed Aug 17, 2022 5:26 pm What happens to poles?
When you insert a knot ? A new set of poles is computed.
onekk wrote: Wed Aug 17, 2022 5:26 pm Probably I'm not guessing something correct as I can't get to work the method removeKnot
Inserting a knot is always possible.
Removing a knot usually need to approximate the curve.
But I have experienced that removeKnot often fails, even with very high tolerance values. I don't know why.
onekk
Post by onekk »
Chris_G wrote: Thu Aug 18, 2022 1:55 pm I don't understand what you're trying the achieve by inserting knots ?
I was trying to find a solution to this question:
Probably in a wrong approximation I could think that the curve is bent due to the irregular spacing of bspline poles.
More generally I'm trying to guess the implications of making surface between two bsplines, using "ruled surfaces" could be a solution, but I could not find a way to "segment" the bspline in a manner that permit to create ruled surfaces that not present the bend shown in the images.
With other curves I could create "curve segments" in both curves and use them to try to avoid delicate segments that cause "bends" or twistings.
I have thought that this could be possible adding poles as result of adding knots to the bspline curve.
Chris_G wrote: Thu Aug 18, 2022 1:55 pm What points ? The points on curve corresponding to the knots ?
Thanks, this is an advancement in my knowledge, (Sorry but I'm "math impaired" :D )
Chris_G wrote: Thu Aug 18, 2022 1:55 pm Inserting a knot is always possible.
Thanks again another information that is difficult to have, from the explanation in both OCCT documentation and FC source code (That not surprisingly is very similar to the OCCT documentation) it seems possible in some cases.
Regards
Carlo D.
onekk
Post by onekk »
Some new code:
(5.19 KiB) Downloaded 39 times
Thanks to @Chris_G invaluable help.
This lead to this:
Hope this could be thought as a solution.
Regards
Carlo D.
onekk
Post by onekk »
Above solution lead to another question?
is it possible to confront the two curves, the original bspline and the "segmented one".
Visually they are different, but I suspect that this could be due even to the different approximation made during the "visualization phase"?
EDIT
even surfaces seems different, so probably is not the best solution.
END EDIT
Regards
Carlo D.
Chris_G
Post by Chris_G »
onekk wrote: Thu Aug 18, 2022 2:59 pm Some new code:
This lead to this:
Great Job !
onekk wrote: Thu Aug 18, 2022 3:13 pm is it possible to confront the two curves, the original bspline and the "segmented one".
I think a segmented curve perfectly matches its parent curve.
onekk wrote: Thu Aug 18, 2022 3:13 pm EDIT
END EDIT
Well, that was exactly the goal, no ?
Build a different surface that looks more natural and avoids the twist.
onekk
Post by onekk »
Chris_G wrote: Thu Aug 18, 2022 4:15 pm Great Job !
Thanks but your contribution is relevant, many of my knowledge about BSplines are from you, @chrisb and few others guys.
Did you know a viable way to confront the two curves, the original bspline and the "segmented one" to see if they overlap without checking all points.
Chris_G wrote: Thu Aug 18, 2022 4:15 pm I think a segmented curve perfectly matches its parent curve.
Do you know a way to check if a curve (the segments) is laying on another curve (the original one)?
Chris_G wrote: Thu Aug 18, 2022 4:15 pm Well, that was exactly the goal, no ?
In fact visually it is good, when needed it could be found a minimal number of segments that will do the job.
Thanks again and Regards.
Carlo D.
onekk
Post by onekk »
edwilliams16 wrote: Wed Aug 17, 2022 8:11 pm
Do you have some idea about the question above:
how to check if "BSPline segments" that form the new "segmented wire" are overlapping the original BSPline.
Sorry for bothering and for the not so clear question.
Regards
Carlo D.
