[SOLVED]How to get the coordinates of a point at the Global Coordinate System ?
manos
Post by manos »
Hello
The following code gives the coordinates of a selected point.
o =FreeCADGui.Selection.getSelectionEx()[0].SubObjects[i]
	ap1=[o.X,o.Y,o.Z,1]
But unfortunately these are coordinates of Local Coor. System.
So the question of the day: How can I get the coordinates of a selected point at the Global Coordinate System ?
Box1.FCStd
(7.7 KiB) Downloaded 26 times
Chris_G
Re: How to get the coordinates of a point at the Global Coordinate System ?
Post by Chris_G »
sel = FreeCADGui.Selection.getSelectionEx()[0]
obj = sel.Object
sub = sel.SubObjects[0]
if hasattr(obj, "getGlobalPlacement"):
    gpl = obj.getGlobalPlacement()
    sub.transformShape(gpl.Matrix)
manos
Post by manos »
Chris_G wrote: Wed Sep 14, 2022 10:21 am
obj = sel.Object
print(' gpl=',gpl)
I got this answer: " gpl= Placement [Pos=(0,0,0), Yaw-Pitch-Roll=(0,0,0)]"
Thanks so much Chris_G but it is not the placement parameters I look for.
Ideally coordinates like those at preselection panel would be my best.
Any help ? Any merciful human being?
Chris_G
Post by Chris_G »
If I select a vertex of your box example, I get the global coordinates :
obj = sel.Object
print(sub.Point)
# >>> Vector (10.0, 0.0, 10.0) = Local Coordinate System
print(sub.Point)
# >>> Vector (11.198563820557883, -2.9883623873011977, 17.03744871391589) = Global Coordinate System
openBrain
Post by openBrain »
The best I know that also support Links is :
sel = Gui.Selection.getSelectionEx('',0)[0]
obj = sel.Object
subobj = sel.SubElementNames[0]
coord = obj.getSubObject(subobj).Point
App.Console.PrintWarning(f"Global coordinates of {subobj} : {coord}\n")
manos
Post by manos »
Splendid @Chris_G.
Thanks again.
manos
Re: [SOLVED]How to get the coordinates of a point at the Global Coordinate System ?
Post by manos »
Thanks @openBrain.
I will try it.
edwilliams16
Post by edwilliams16 »
Just to clarify. If you use @Chris_G 's code on a vertex of a linked object, you'll get the global coordinates of the original, not the link. With @openBrain 's code you'll get the global coordinates of the linked object's vertex that you selected. This is all moot if you don't use links. Try it on the enclosed file.
To get the global placement of a selected linked object, you can use
for sel in Gui.Selection.getSelectionEx('',0):
  for path in sel.SubElementNames if sel.SubElementNames else ['']:
    placement = sel.Object.getSubObject(path, retType=3) # retType 3 returns the placement. Check the doc string for more info
    print('%s.%s -- %s' % (sel.Object.Name, path, placement))
Box1Link.FCStd
(8.7 KiB) Downloaded 24 times
