I'm starting as beginner regarding macro on Freecad.
Is it possible to export sketch or spreadsheet data as txt with specific format?
For instance consider the data below
Sketch.Constraints.Width (this variable has the value = 1500)
Spreadsheet.A15 (this variable has the value = 750)
Pad003.Lenght (this variable has the value = 500)
Can I export the above data in the below format?
S1 = 1500.00
S2 = 750.00
S3 = 500.00
If it's possible, could you share the syntax to do it and I will learn from there.
How to export TXT
Re: How to export TXT
Here is an example of exporting to csv.
Maybe adapt to your data.
import csv
with open('c:\\mydocs\\tube.csv', 'a') as f:
writer = csv.writer(f)
#writer.writerow([])
if TOTALNUM == 1:
writer.writerow(['1', L12, A123, 0, 0, SETBK1, LGBD1])
writer.writerow(['2', L23, A234, THETA, TOTAL, SETBK2, LGBD2])
writer.writerow(['3', L34, 0, 0, 0, 0, 0])
if TOTALNUM > 1:
if PDT == 1:
if PDT > 1 and PDT < TOTALNUM:
writer.writerow([PDT + 1, L23, A234, THETA, TOTAL, SETBK2, LGBD2])
if PDT == TOTALNUM:
writer.writerow([PDT + 2, L34, 0, 0, 0, 0, 0])
Wasn't able to catch how do you got a internal variable and export it.
From you code looks like you were creating a ROW.
How to access and existing data?
Normally you export results:
But you would have a header row also.
Are you wanting the s = also? I suggest looking up exporting to text file in python, and maybe you will find a closer example to fit what you are trying to do.
1500.00
750.00
500.00
Once I mention syntax, I think you answer in the last post isn't the good way to go, but thanks for trying to help.
To be able to save a TXT I found an official documentation, see below:
https://wiki.freecadweb.org/Dialog_crea ... ting_files
To access internal drawing variable in order to export, I was able to reach to the syntax below with a lot of trial and error.
The above syntax will access the value of the cell A11 in the spreadsheet, and so I can save it, see below as I implemented:
Spreadsheet.A11 = 550.0 mm
float() = 550.0 (this will remove the unit)
{:.2f}".format = 550.00 *format to 2 decimals
str() = convert to string
so in the exported txt file I will find:
S1 = 550.00
App.ActiveDocument.Spreadsheet.A11
file.write("S1 = "+str("{:.2f}".format(float(App.ActiveDocument.Spreadsheet.A11)))+"\n")
S1 = 550.00
