[solved] Py basics question. reformatting text
llll
Post by llll »
Task:
get some data (1st block)
if there's Vector tuples, replace "Vector" with "App.Vector" (2nd block)
Text is printed to console (unintended) with corrected formatting, but new list is not being remembered
place = []
length = []
objects = [o.Label for o in App.ActiveDocument.Objects if hasattr(o,"getGlobalPlacement") and o.Shape.Length]
num = 0
for i in objects:
    loc = eval(f'doc.{i}.Placement.Base')
    place.append(loc)
    len = eval(f'doc.{i}.Shape.Length')
    length.append(len)
print(place)
length_ = []
place_ = []
newL = [place_, length_]
Lists = [place,length]
num = 0
for i in Lists:
    if 'Vector ' in str(i):
        str(i).replace('Vector ', 'App.Vector')
        for j in i:
            newL[num].append(j)
    num +=1
print(place_)
Thanks, feel free to point out any less than ideal practices as you see them
edit:
solution
import FreeCAD
def format(v):
    if 'Vector ' in str(v):
        a = str(v).replace('Vector ', 'App.Vector')
        return a
    else:
        return v
place = []
length = []
doc = FreeCAD.getDocument("just_spline")
objects = [o.Name for o in doc.Objects if hasattr(o,"getGlobalPlacement") and o.Shape.Length]
for i in objects:
    loc = doc.getObject(i).Placement.Base
    var = format(loc)
    place.append(var)
    len = doc.getObject(i).Shape.Length
    var = format(len)
    length.append(var)
just spline.FCStd
(13.77 KiB) Downloaded 17 times
openBrain
Re: Py basics question. reformatting text
Post by openBrain »
Check variables.
In 2nd 'for' loop, you use 'lol' which doesn't exist.
At the end you print 'place_', which is initialized to empty list then never touch again.
Other things :
Don't use 'Label', use 'Name'.
Check for 'Placement' attribute, not 'getGlobalPlacement'.
'eval' is pretty dangerous, you should use FC function (can't remember if it's 'doCommand' or 'runCommand')
You should better tell what this code is aiming at (functionnally) because it looks very weird.
llll
Post by llll »
openBrain wrote: Wed Sep 28, 2022 5:22 am Check variables.
A residual error made when posting, srry, was using "lol" as list of lists.
newL[num].append(j) == place_.append(j) == same error
openBrain
Post by openBrain »
Please post a tested code. There still are obvious problems.
llll
Post by llll »
openBrain wrote: Wed Sep 28, 2022 6:13 am .
That's all I have + some draft squiggles in file... It shows list problem I wanted help with
The eval is used only since idk how to do this:
for i in objects:
    loc = doc.i.Placement?
edit: Does it help to know I was playing around with console: first block is only to show second block failure.
just spline.FCStd
(13.77 KiB) Downloaded 15 times
onekk
Post by onekk »
Probably you are missing "the point".
You should not post partial code, but a "working" code, that loaded in the FC Macro editor will run and show the problem.
So if the code has to run with some related file you should post the file, or a hardcoded data source that mimic what the code is expecting.
This is the concept of "Minimal Working Example".
An helper must not guess thing, it has to solve (if possible) problems.
If not it will be hard for an helper to supply help. And when volunteer helpers will be tired there will be simply "no help at all".
Regards
Carlo D.
- Various other stuffs.
llll
Post by llll »
onekk wrote: Wed Sep 28, 2022 8:28 am Probably you are missing "the point".
Agreed. it took me 90 minutes to get the point. Still after a solution should someone have the motivation.
ty
onekk
Post by onekk »
Sadly it's still not clear the question.
see next post for some code that may be a correct guess or not.
Regards
Carlo D.
onekk
Post by onekk »
llll wrote: Wed Sep 28, 2022 12:19 pm ...
with "just_splin.FCStd open as document this code will show information you need in a more Pythonic Way.
import FreeCAD
place = []
length = []
for i in objects:
    place.append(loc)
    length.append(len)
    print(f"{i} loc: {loc}  len: {len}")
Note the use of Name that is unique and identify the object and the absence of eval.
But the point is not clear on what you are trying to achieve.
Regards
Carlo D.
