myCylinder = FreeCAD.ActiveDocument.getObject("Cylinder")
yc = float (myCylinder.Placement.Base.y)
I use this code to take the y value of the position. How can i do to take the value of the y of the axis?
(version 0.20.1 windows)
How can i take the x, y, and z of the axis by a part object in python?
Re: How can i take the x, y, and z of the axis by a part object in python?
I may not understand: The origin of a cylinder is on the axis. Getting the y value of the cylinder gives you the y value of the axis.
Sorry, I badly explayned myself: i need to import the rotation axis (i don't know the exact name, but is the one in the attached image)
- axis.png (3.39 KiB) Viewed 514 times
myCylinder.Placement.Rotation.Axis.y
thank you, that was what i needed
myCylinder.Placement.Rotation.RawAxis.y
If you change x and y of the axis to -1 in the property editor then
