GuiUp check in viewprovider code: why?
Roy_043
Post by Roy_043 »
In the viewprovider code of Draft objects you can find:
if App.GuiUp:
    from pivy import coin
    import FreeCADGui as Gui
    import Draft_rc
    # The module is used to prevent complaints from code checkers (flake8)
    bool(Draft_rc.__name__)
Why the GuiUp check? Can viewproviders be loaded if the GUI is not available?
Re: GuiUp check in viewprovider code: why?
Post by Kunda1 »
I believe this was vocx's approach to make Draft future friendly if it was to be run headless.
reference: https://forum.freecadweb.org/viewtopic.php?f=10&t=44101
Roy_043
Post by Roy_043 »
Thanks for the link. It is related, but not quite what I mean. AFAIK viewproviders are not loaded if the GUI is not available, so the GuiUp check, in view_base.py for example, seems superfluous.
Link to the code:
https://github.com/FreeCAD/FreeCAD/blob ... py#L40-L45
