Question about calling function from parent class
Roy_043
Post by Roy_043 »
In the Draft code I sometimes encounter functions similar to:
    def onDocumentRestored(self, obj):
        """Execute code when the document is restored.
        It calls the parent class to add missing annotation properties.
        super().onDocumentRestored(obj)
I do not fully understand why they are there. They override the function from the parent class, and then only call that function. The code obviously also works without them. Are they perhaps just there to inform the programmer? Some coding standard?
onekk
Re: Question about calling function from parent class
Post by onekk »
I don't know exactly, but speaking about annotations, I remember a discussion with Yorick about a way to make "annotations styles" works.
As they are saved inside some custom fields to not modify the FCStd format, there were a mechanism that check if a document contains these "style data" and reapply them once the document is opened.
As I see a call of the super() class probably the main class of FC, so it reminds me that mechanism.
@yorik
Hope it helps.
Regards
Carlo D.
- Various other stuffs.
