[SOLVED] How to connect fetures (as sub feature) to parent feature?
Evgeniy
Post by Evgeniy »
For example how to make this structure from features?
How to make feature is connectable?
And is it possible to attach sub-sub-fetures to sub-feature?
Is there limits in the levels of nesting?
This code can be used as a basis:
# -*- coding: utf-8 -*-
import FreeCAD
import FreeCAD as App
import FreeCADGui
obj = App.ActiveDocument.addObject('App::FeaturePython', 'Molecula')
MoleculaFeature(obj)
MoleculaViewProvider(obj.ViewObject)
obj = App.ActiveDocument.addObject('App::FeaturePython', 'Atom')
H_AtomFeature(obj)
H_AtomViewProvider(obj.ViewObject)
O_AtomFeature(obj)
O_AtomViewProvider(obj.ViewObject)
O_AtomFeature(obj)
class MoleculaFeature():
    def __init__(self, obj):
        self.Type = 'MoleculaFeature'
        obj.addProperty('App::PropertyString', 'Description', 'Base', 'Feature description').Description = ""
        obj.Proxy = self
        self.obj = obj
    def onChanged(self, obj, prop):
        val = obj.getPropertyByName(prop)
    def execute(self, obj):
        App.Console.PrintMessage("MoleculaFeature execute \n")
class MoleculaViewProvider:
        obj.Proxy = self
    def getDetailPath(self, subname, path, append):
        FreeCAD.Console.PrintMessage("MoleculaViewProvider getDetailPath: " + str(subname) + " " + str(path) + " " + str(append) + "\n")
    def getElementPicked(self, pp):
        FreeCAD.Console.PrintMessage("MoleculaViewProvider getElementPicked: " + str(pp) + "\n")
    def attach(self, obj):
        from pivy import coin    # Without that icon is be gray
        self.standard = coin.SoGroup()
        obj.addDisplayMode(self.standard,"Standard");
    def updateData(self, obj, prop):
        return
    def getDisplayModes(self, obj):
        return ["Standard"]
    def getDefaultDisplayMode(self):
        return "Standard"
    def setDisplayMode(self,mode):
        return mode
        return
    def getIcon(self):
        return """
               /* XPM */
               static char *Some_icon_xpm[] = {
               /* columns rows colors chars-per-pixel */
               "16 16 3 1 ",
               "  c None",
               ". c #00AAFF",
               "+ c #FF0000",
               /* pixels */
class H_AtomFeature():
        self.Type = 'AtomFeature'
        obj.Proxy = self
        self.obj = obj
        App.Console.PrintMessage("H_AtomFeature execute \n")
class O_AtomFeature(H_AtomFeature):
        App.Console.PrintMessage("O_AtomFeature execute \n")
class H_AtomViewProvider():
        obj.Proxy = self
        FreeCAD.Console.PrintMessage("AtomViewProvider getDetailPath: " + str(subname) + " " + str(path) + " " + str(append) + "\n")
        FreeCAD.Console.PrintMessage("AtomViewProvider getElementPicked: " + str(pp) + "\n")
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #00AAFF",
               /* pixels */
               "   +++o++o+++   ",
               "   +++o++o+++   ",
               "   +++oooo+++   ",
               "   +++o++o+++   ",
               "   +++o++o+++   ",
class O_AtomViewProvider(H_AtomViewProvider):
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #FF0000",
               /* pixels */
               "    +++oo+++    ",
               "    ++o++o++    ",
               "    ++o++o++    ",
               "    ++o++o++    ",
               "    +++oo+++    ",
Founder
Re: How to connect fetures (as sub feature) to parent feature?
Post by wmayer »
What you basically have to do is implementing the method claimChildren() in your MoleculaViewProvider class. This method must return a list of the objects that should be underneath the tree item. In the modified code I added a PropertyLinkList to MoleculaFeature and assigned a list of the objects from outside. The view provider then updates itself when updateData() is called.
import FreeCAD
import FreeCADGui
atoms = []
atoms.append(obj)
H_AtomFeature(obj)
atoms.append(obj)
O_AtomFeature(obj)
atoms.append(obj)
O_AtomFeature(obj)
obj.Atoms = atoms
        obj.addProperty('App::PropertyLinkList', 'Atoms', 'Base', 'Feature description')
        obj.Proxy = self
        self.obj = obj
        obj.Proxy = self
        self.atoms = []
        self.atoms = obj.Atoms
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
    def claimChildren(self):
        return self.atoms
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               ". c #00AAFF",
               "+ c #FF0000",
               /* pixels */
        obj.Proxy = self
        self.obj = obj
        obj.Proxy = self
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #00AAFF",
               /* pixels */
               "   +++o++o+++   ",
               "   +++o++o+++   ",
               "   +++oooo+++   ",
               "   +++o++o+++   ",
               "   +++o++o+++   ",
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #FF0000",
               /* pixels */
               "    +++oo+++    ",
               "    ++o++o++    ",
               "    ++o++o++    ",
               "    ++o++o++    ",
               "    +++oo+++    ",
Sure, no problem. The idea is the same. Just implement the claimChildren() of the view provider
import FreeCAD
import FreeCADGui
obj1 = App.ActiveDocument.addObject('App::FeaturePython', 'Atom')
H_AtomFeature(obj1)
H_AtomViewProvider(obj1.ViewObject)
obj2 = App.ActiveDocument.addObject('App::FeaturePython', 'Atom')
O_AtomFeature(obj2)
O_AtomViewProvider(obj2.ViewObject)
obj2.Atom = obj1
obj3 = App.ActiveDocument.addObject('App::FeaturePython', 'Atom')
O_AtomFeature(obj3)
O_AtomViewProvider(obj3.ViewObject)
obj3.Atom = obj2
obj4 = App.ActiveDocument.addObject('App::FeaturePython', 'Molecula')
MoleculaFeature(obj4)
MoleculaViewProvider(obj4.ViewObject)
obj4.Atoms = obj3
        obj.Proxy = self
        self.obj = obj
        obj.Proxy = self
        self.atoms = []
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
        return self.atoms
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               ". c #00AAFF",
               "+ c #FF0000",
               /* pixels */
        obj.addProperty('App::PropertyLink', 'Atom', 'Base', 'Feature description')
        obj.Proxy = self
        self.obj = obj
        obj.Proxy = self
        self.atom = []
        self.atom = [obj.Atom]
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
        return self.atom
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #00AAFF",
               /* pixels */
               "   +++o++o+++   ",
               "   +++o++o+++   ",
               "   +++oooo+++   ",
               "   +++o++o+++   ",
               "   +++o++o+++   ",
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #FF0000",
               /* pixels */
               "    +++oo+++    ",
               "    ++o++o++    ",
               "    ++o++o++    ",
               "    ++o++o++    ",
               "    +++oo+++    ",
Evgeniy
Post by Evgeniy »
wmayer wrote: Fri Dec 09, 2022 12:33 pm What you basically have to do is implementing the method claimChildren() in your MoleculaViewProvider class.
Big thanks! It's really not difficult and convenient.
Only now I realized that I had mixed up the atoms. There should be one O atom and two H atoms. Now the example is chemical correct.
import FreeCAD
import FreeCADGui
# Array for atoms
atoms = []
# Add O atom
atoms.append(obj)
O_AtomFeature(obj)
# Add H atom
atoms.append(obj)
H_AtomFeature(obj)
# Add H atom
atoms.append(obj)
H_AtomFeature(obj)
# Create molecula and connect atoms to it
obj.Atoms = atoms
        obj.Proxy = self
        self.obj = obj
        obj.Proxy = self
        self.atoms = []
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
        return self.atoms
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               ". c #00AAFF",
               "+ c #FF0000",
               /* pixels */
class O_AtomFeature():
        obj.Proxy = self
        self.obj = obj
class H_AtomFeature(O_AtomFeature):
class O_AtomViewProvider():
        obj.Proxy = self
        return
        return ["Standard"]
        return "Standard"
        return mode
        return
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #FF0000",
               /* pixels */
               "   ++++oo++++   ",
               "   +++o++o+++   ",
               "   +++o++o+++   ",
               "   +++o++o+++   ",
               "   ++++oo++++   ",
class H_AtomViewProvider(O_AtomViewProvider):
    def getIcon(self):
        return """
               /* XPM */
               "16 16 3 1 ",
               "  c None",
               "o c #FFFFFF",
               "+ c #00AAFF",
               /* pixels */
               "     +o++o+     ",
               "     +o++o+     ",
               "     +oooo+     ",
               "     +o++o+     ",
               "     +o++o+     ",
# End
It would be nice if those who write articles in the freecad wiki would add this code to some article on the topic of scripting objects.
