After copyObject(), the object has no attribute
xianyu
Post by xianyu »
I'm improving a project.When I copy an object, the new object will display this error, but my original object is OK.The "Data-Property" of the new object also displays the "shapetype" attribute. What's the reason?
File "Front_Surface.py", line 66, in onChanged
if obj.shapetype == "Conic":
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'shapetype'
class FrontSurface:
    def __init__(self):
        doc = FreeCAD.ActiveDocument
        obj= doc.addObject("Part::FeaturePython", "FrontSurface")
        obj.addProperty("App::PropertyEnumeration","shapetype","Shape","specifies type").shapetype=["Conic","Cylinder","Asphere"]
        obj.addProperty("App::PropertyFloat", "curv", "Shape", "central curvature").curv = 0
        obj.addProperty("App::PropertyFloat", "cc", "Shape", "conic constant").cc = 0
    def onChanged(self, obj, prop):
        proplist = ["curv", "cc"]
        if prop in proplist:
                obj.shapeclass.curvature.set_value(obj.curv)
                obj.shapeclass.conic.set_value(obj.cc)
Freecad novice, A Python enthusiast
Chris_G
Re: After copyObject(), the object has no attribute
Post by Chris_G »
I suspect it is the same problem as document restoring :
- the new object is created
- the properties are added in alphabetical order
- a value is assigned to the new property, which triggers the onChanged method
So, when the curv and cc properties are created and initialized, the shapetype property is not yet created.
Does the error message appear twice ?
Does the error message appear when you open a document containing such object ?
xianyu
Post by xianyu »
Chris_G wrote: Fri Dec 09, 2022 6:28 am Does the error message appear twice ?
Hi, Chris_G
Yes, the error message appears twice.
Chris_G wrote: Fri Dec 09, 2022 6:28 am Does the error message appear when you open a document containing such object ?
I don't understand what this means
But if I save the file as ". FCStd" and open this file, the same error message will appear
Edit:
Also, this error will occur in copy
File "E:\gitfreecad\build\bin\lib\json\encoder.py", line 257, in iterencode
return _iterencode(o, 0)
File "E:\gitfreecad\build\bin\lib\json\encoder.py", line 179, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
<class 'TypeError'>: Object of type FloatOptimizableVariable is not JSON serializable
Chris_G
Post by Chris_G »
xianyu wrote: Fri Dec 09, 2022 6:45 am Hi, Chris_G
Then you can disable onChanged while the object is being restored with :
def onChanged( self, obj, prop):
    if "Restore" in obj.State:
        return
xianyu wrote: Fri Dec 09, 2022 6:45 am Edit:
Also, this error will occur in copy :
This means that FC is not able to save the FloatOptimizableVariable object.
So you need to handle the save / restore of this object by yourself with :
def __getstate__(self):
    # create and return a dict that contains all the data needed to create the FloatOptimizableVariable object
def __setstate__(self, state):
    # create the FloatOptimizableVariable object with the dict "state"
    self.FloatOptimizableVariable = object built from state data
    return
xianyu
Post by xianyu »
Chris_G wrote: Fri Dec 09, 2022 8:34 am ...
Thank you very much. It worked.Solved a big problem for me :D
xianyu
Post by xianyu »
I found that this error also occurs for some "external" custom attributes. How can I solve this problem?
Were these "external" custom properties not successfully copied?
#example
class FrontSurface:
    def __init__(self, shapedata, aperturedata, lc):
        obj.addProperty("App::PropertyPythonObject", "shapeclass", "Shape", "").shapeclass = shapedata
        obj.addProperty("App::PropertyPythonObject", "apertureclass", "Aperture", "").apertureclass = aperturedata
        obj.addProperty("App::PropertyLink", "LocalCoordinatesLink", "Coordinates", "local coordinate system").LocalCoordinatesLink = lc
Chris_G
Post by Chris_G »
I suppose the 3rd property LocalCoordinatesLink is correctly handled by FreeCAD.
For the 2 other, shapeclass and apertureclass, I think you need to make the python objects JSON serializable.
Maybe this can help :
https://pynative.com/make-python-class- ... ializable/
Roy_043
Post by Roy_043 »
Chris_G wrote: Fri Dec 09, 2022 8:34 am Then you can disable onChanged while the object is being restored with :
        return
Thanks. Is there something similar for ViewObjects?
Chris_G
Post by Chris_G »
I am afraid no :
AttributeError: 'Gui.ViewProviderDocumentObject' object has no attribute 'State'
Roy_043
Post by Roy_043 »
Thanks again. In the Draft code we have situations where we have to check for the presence of multiple view properties before we can do something in onChanged. A State property could maybe help in such cases.
