I don't think this can work. Are you sure this is the correct code?onekk wrote: ↑Fri Jan 27, 2023 1:21 pmCode: Select all
objects = doc.Objects for obj in objects: if obj.TypeId in ("App::"): pass else: doc.removeObject(obj.Name)
How to check if an object has been deleted?
Re: How to check if an object has been deleted?
Yes I'm sure, I use it almost daily in this method:
def clear_doc(doc_name):
"""Clear the document deleting all the objects.
Hack courtesy of edwilliams16
Parameters:
name type description
doc_name string document name
doc = FreeCAD.getDocument(doc_name)
doc.recompute()
for obj in objects:
pass
else:
When called it deletes all the content of document which doc_name is the name.
I don't know why is excluding objects that have as TypeID equal to App::, but it works without raising exceptions.
Regards
Carlo D.
Sorry for the multiple edits. today is not a great day
- Various other stuffs.
Maybe I'm missing something but I commented this out (and the similar line a dozen lines above, to be sure), and I see no difference in behavior. The cloned part has the same color as the original one...Roy_043 wrote: ↑Thu Jan 26, 2023 9:06 pm The delay in make_clone.py:
https://github.com/FreeCAD/FreeCAD/blob ... ne.py#L129
- Create a Part_Box.
- Change the color of some of its faces with Part_FaceColors.
- Create a Draft_Clone.
- Result without the workaround: the clone does not display the correct face colors (DiffuseColor). Although the ShapeColor is correct.
- Save and reopen the file.
- Result: the face colors of the clone are now displayed correctly.
OS: Windows 8.1 Version 6.3 (Build 9600)
Version: 0.21.0.31641 (Git)
Hash: d28d63b87b60161419c6c0c532fbbfaed96926b8
Python 3.10.8, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
OS: Ubuntu 22.04.1 LTS (ubuntu:GNOME/ubuntu)
@Roy_043 Didn't get it was about the faces. Will retest later. Thx.
The code may work in certain cases, but not as intended. Just create a document with a PD Body (without any additional features) and run:
doc = App.ActiveDocument
for obj in objects:
print(obj.TypeId)
pass
else:
PartDesign::Body
App::Origin
File "<input>", line 6, in <module>
RuntimeError: This object is currently not part of a document
This should be:
if "App::" in obj.TypeId:
But even with that mod the code makes certain assumptions that need not apply. "App::" type objects occur as subelements of PD Bodies. but not just there.
For example:
doc.addObject("App::DocumentObjectGroup")
Good to know that is only a partial.workaround.
It is working, but I usually make Part WB DocumentObjects, part.Compounds and maybe some Boolean operations, even PD sketches and features, not much more.
Code was elaborated by @edwilliams16 some time ago probably o a couple of years to solve a specific problem, sadly I could not find the specific post.
I will be happy to know a more generic way to avoid errors when "emptying" a FCStd file.
Regards
Carlo D.
I can't find the original post not a problem now at least for me. If some reliable solution will be found it will be s better thing for all FreeCAD users.edwilliams16 wrote: ↑Sat Jan 28, 2023 5:53 pmI don't remember it - to today's eyes it doesn't look correct.
My primary interest is that FreeCAD will improve and will better.
Regards.
Carlo D.
