[SOLVED]persistent storage between different macros
piffpoof
Postby piffpoof » Fri Dec 12, 2014 1:36 pm
hello
is there a supported method for persistent storage between two macros in one session of FreeCAD - aside from writing out to file?
I have a number of macros which operate on a collection of geometric objects which have a screen portrayal:
1 macro#1: the objects are created and positioned from file, a data structure created by the macro holds all the objects and their view objects
2 macro#2: the user iterates over the object model until happy, they do this exclusively through the FreeCAD GUI, there is no involvement with macro code. Also they are only affecting the View Object at this point they do not alter the geometric object model.
3 macro#3: the program takes the accumulated GUI results from macro#2, combines them with the values in the data structure from macro#1, writes them out to the permanent storage in a file
I'm not looking for persistence over multiple invocations of FreeCAD, I would use the file structure for that if needed. What I am looking for is someway to maintain data structures between macro#1 and macro#3, all taking place in the same FreeCAD session.
I have tried to use Global variables but they seem to get garbage collected...
thanks
Dean
jreinhardt
Re: persistent storage between different macros
Postby jreinhardt » Fri Dec 12, 2014 3:15 pm
Sounds like this could be realized by letting step 1 create a custom python feature
Scripted_objects
in that way you can store data directly on the object (along with the geometric shape)
and access it later.
This even works after saving and loading to a FCstd file.
BOLTS, standard parts library for FreeCAD Thread, Help with Translation
piffpoof
Postby piffpoof » Fri Dec 12, 2014 3:51 pm
jreinhardt wrote:Sounds like this could be realized by letting step 1 create a custom python feature
Scripted_objects
hi
I have steps 1,2 & 3 all working from the console as one large Python file as there is persistent storage while they run on the console. I am now trying to split them into 3 Macros and because the Macros run in a different name space than the console there is no persistent storage between one Macro execution and the next. At least not that I can find out about.
From reading the page you mentioned, it seems to write out binary objects to FCStd files, something I already have working (although not in FCStd format file). I don't want to write the intermediate results out to a data file as it seems rather old world in an OO environment. But if I have to I guess I have to. I am trying to find keep the intermediate results in memory, I could store them on an object from the classes mentioned on the page you mentioned but it would surely get garbage collected as my own class does once all references to it end when the macro finishes executing.
Dean
yorik
Site Admin
Postby yorik » Fri Dec 12, 2014 4:25 pm
There is a very simple way:
FreeCAD.myVariable = "something"
piffpoof
Postby piffpoof » Fri Dec 12, 2014 6:56 pm
yorik wrote:There is a very simple way:
worked a charm
thanks
Dean
microelly2
Postby microelly2 » Fri Dec 12, 2014 11:52 pm
I use this too,
but there should be some naming space conventions to avoid
that multiple macros/workbenches share/modify/overwrite the same attribute.
ideas
FreeCAD.Macro.MyMacro.myAttr=7
FreeCAD.WB.MyWorkbench.myAttr=8
FreeCAD.MyWorkbench.myAttr=9
