MACRO:Work Feature 2014_12
Charles Gull
Re: MACRO:Work Feature 2014_12
Post by Charles Gull »
Hi mario52,
thanks for your support.
yes, the command is Axis Plane/Plane.
It doesn't needa fancy file. In my case, I can just create a completely new and fresh start model. It is not possible to create an axis using any of the base co-ordinate system planes. :(
If I add any extra planes, it doesn'twork with them either. :(
If I create a simple block [pad], it works fine between any two solid faces. :D
If I use 1 face and 1 datum plane, it fails. :(
manos
Post by manos »
mario52 excuse me to not respond to your post. I thought the thread was closed. Thanks a lot.
mario52
Post by mario52 »
Hi
@manos no problem you have all the time (I thought the thread was closed ... jamais)
@Charles Gull for the error
Charles Gull wrote: Sun Aug 15, 2021 8:24 pm yes, the command is Axis Plane/Plane.
the error is in the file WF_selection.py in
def get_SelectedObjects(info=0, printError=True):
but in this time i was unable to correct , wait the author rentlau_64
the macro is created before including the "DatumPlane" and this "DatumPlane" is not yet recognized by WorkFeature
come and see from time to time if it is corrected
or creat one plane with WorkFeature and convert it in DatumPlane with my little macro
Macro_D_Un_Jour_Convert_Plane_WFeatures_To_Part_Plane.FCMacro and attach it on face with the FreeCAD tools
sorry
mario
