MACRO:Work Feature 2014_12
Re: MACRO:Work Feature 2014_12
Mario52,
Woaw The MACRO Recipe wiki is very nice.
Thank you very much for your help.
I will continue to work on these tools and keep all of you inform.
See you soon.
Rentlau_64
See you soon.
Rentlau_64
hi
a christmas gift
we must also put some examples
mario
a christmas gift
mario
hi
with the new installation I have good return of icons i ave replace alls image
before and after
mario
before and after
mario
Mario52,
Find the new release of Work feature with fix for sketch and bbox. Wmayer,
I guess I fix some of the issues you described. Feel free to give me your comments.
Thank you very much to all of you.
Rentlau_64
Rentlau_64
hi
done Macro_WorkFeatures
EDIT : 14:29
a suggetion section plane
1: it would be interesting to have a function like Macro_Align_View_to_Face
2: adjusting the camera to a position (example with spinBox : x=45°y=25° z=15°) and create plane (very interesting)
ex : (no finished) mario
EDIT : 14:29
Great!
Object(s) center:
Works correctly with a sketched built of one element. When the sketch has e.g. a rectangle and a circle and i Select the circle I get this:
* The command Plane=(Point, _|Axis) insists to have a line and point not lying on this line. Why? The selected axis becomes the normal of the plane and to get a unique plane only one point is needed independent where it is
Object(s) center:
m_wire = [<Part::Part2DObject>, <Part::Part2DObject>]
m_wire = [<Part::Part2DObject>, <Part::Part2DObject>]Traceback (most recent call last):
File "C:/Projects/FreeCAD-git/macros/WF_2014_12_26.FCMacro", line 867, in plot_centerObjectPoint
Vector_Objects_Center = centerObjectsPoint(m_objs,info=0)
File "C:/Projects/FreeCAD-git/macros/WF_2014_12_26.FCMacro", line 436, in centerObjectsPoint
xmax, xmin, ymax, ymin, zmax, zmin = minMaxObjectsLimits(objs,info=info)
File "C:/Projects/FreeCAD-git/macros/WF_2014_12_26.FCMacro", line 383, in minMaxObjectsLimits
box = m_wire.Shape.BoundBox
AttributeError: 'list' object has no attribute 'Shape'
Guys,
The Macro WorkFeatures wiki page is great, but what is less great is linking a ZIP archive. Some people have issues with having to download something without being able to look at the code first.
Please consider sharing your work using a source code hosting service like GitHub. What's great with it is that other people can easily fork your work, make enhancements and then request their changes to be merged, which can be done through the web interface.
Git requires some getting used to but it's worth it.
For a single large script that exceeds the limit of the wiki, you can use https://gist.github.com/ and simply paste the code.
Mario52, Wmayer,
Find the MACRO with the 2 issues pointed by Wmayer corrected. Normand,
I am learning GIT HUB and will put soon the MACRO on it.
Rentlau_64
Rentlau_64
hi
i modify the link
thanks
mario
i modify the link
I will adopt this system for my big macronormandc wrote:For a single large script that exceeds the limit of the wiki, you can use https://gist.github.com/ and simply paste the code.
thanks
mario
Mario52,
I completed one release of Work Feature Macro with:
1 One "Align To" button to allow the user align the view either
- perpendicular to a selected Face,
- aligned to a selected Edge,
- aligned along 2 points.
2 and with a "Create Plane" button to create a plan
perpendicular to the view and either
- attached to a point defined by a mouse click or
- attached to an alredy existing point
I think I also corrected the bug you gave me concerned the bounding box.
If you feel it is ok could you upfate the Macro recipes for me?
Thank you so much for your help.
Merci d'avance pour ton aide.
Rentlau_64
Rentlau_64
- WF_2015_01_18.tar.gz
- (158.84 KiB) Downloaded 328 times
- AlignTo.png (29.5 KiB) Viewed 3239 times
