MACRO:Work Feature 2014_12
Re: MACRO:Work Feature 2014_12
mario52 I did as you wrote but I got the message:
NameError: name 'NormalA' is not defined.
Thanks anyway.
Thanks anyway.
hi
@manos try this
mario
@manos try this
## original code by JMG https://forum.freecadweb.org/viewtopic.php?f=22&t=9056&start=60#p79922
## 05/06/2021
## Mario52
## https://forum.freecadweb.org/viewtopic.php?f=22&t=9056&start=210
import Draft, Part
SelObj = Gui.Selection.getSelectionEx()
Sel = Gui.Selection.getSelection()
tolerance = 1e-10
try: # verify if 2 faces hare selected
face = 0
if SelObj[0].SubObjects[0].ShapeType == "Face":
face+=1
try:
if SelObj[1].SubObjects[0].ShapeType == "Face":
face+=1
except Exception:
try:
if SelObj[0].SubObjects[1].ShapeType == "Face":
face+=1
except Exception:
print("Oups Bad selection")
if face == 2:
try:
NormalA = SelObj[0].SubObjects[0].normalAt(0,0)
VAB = (SelObj[1].SubObjects[0].CenterOfMass-SelObj[0].SubObjects[0].CenterOfMass).normalize()
#print("(1) ",NormalA," ",VAB)
except Exception:
try:
fa = int(SelObj[1].SubElementNames[0][4:])
NormalA = Sel[1].Shape.Faces[fa - 1].normalAt(0,0)
VAB = (Sel[0].Shape.CenterOfMass-SelObj[1].SubObjects[0].CenterOfMass).normalize()
#print("(2) ",NormalA," ",VAB)
except Exception:
try:
VAB = (SelObj[0].SubObjects[0].CenterOfMass-SelObj[0].SubObjects[1].CenterOfMass).normalize()
#print("(3) ",NormalA," ",VAB)
except Exception:
try:
NormalA = Sel[1].Shape.Faces[0].normalAt(0,0)
VAB = (Sel[0].Shape.CenterOfMass-Sel[1].Shape.CenterOfMass).normalize()
#print("(4) ",NormalA," ",VAB)
except Exception:
#print("Oups")
None
try:
#print(NormalA.dot(VAB))
if NormalA.dot(VAB) == 0.0:
FreeCAD.Console.PrintMessage("\nCoplanar faces \n")
else:
FreeCAD.Console.PrintMessage("\nNon coplanar faces \n")
except Exception:
print("Oups Non VAB value")
else:
print("Oups select 2 faces")
except Exception:
I tried. So far so good.
Will you include it in a next version of Workfeatures macro ?
Thanks Mario52
Thanks Mario52
Hi
unzip the file and copy this new file WF.py in WorkFeature mod instead the original WF.py
and report ...
mario
and report ...
mario
mario52 I copied the WF.py to the folder: /home/manosd/.freeCAD/Macros .
I am not sure that it is the appropriate folder because of the file I attached.
Any hint ?
Any hint ?
- start_WF_WorkFeature.FCMacro
- (1.94 KiB) Downloaded 55 times
hi
not the good folder, in Windows the folder is
/home/manosd/.freeCAD/Macros is the macros folder (start_WF_WorkFeature.FCMacro is the lauch macro for WorkFeature)
see in (search and replace the WF.py macro)
mario
C:\Users\UserName\AppData\Roaming\FreeCAD\Mod\WorkFeature\WorkFeature
/home/manosd/.freeCAD/Mod/WorkFeature/WorkFeature
Thanks mario52 I will try it.
- Charles Gull
I like the look of this macro and it's listed features hold greatpromise.
I am having a problem with creating an axis between two planes.
If I select two plannar surfaces from my model and axis is created, no problem.
If one, or both, of the plannar surfaces is a datum plane, it fails. Error message says that the selections are parallel. I should change my selection. They are very muchnot parallel.
hi
I think WF is not yet adapted for the datum plane
want to give an example file fot testing
and the command used (maybe Axis Plane/Plane) ?
mario
mario
