Wmayer,
Axis=(Plane,Plane): For a directly created cube it works but when you create a rectangle sketch and pad it then it doesn't work.
You are rigth I have some problem with sketch and objects generated from sketch as a pad rectangle done by "part design" workbench but no issue with pad done by "part" workbench. I need to work to fix that. If you have any idea of the differences between a pad from "part design" and a pad from "part" it may help me to chase the issue. (I already localised an issue with skecths in the minMaxObjectsLimits() function)
Concerning :
That's the whole trick. However, the little downside is that when loading the .ui file into Qt designer you can't see the icons.
and
Then you did this manually? That might become cumbersome because your changes are lost whenever re-creating te .py file from the .ui file.
In order to see the icons into QT4 designer, I assume your ui file is in the same directory than Icons directory,
so I fixed the ui file to have the icons available into QT4 with:
<normaloff>Icons/WF_Axes.svg</normaloff>Icons/WF_Axes.svg</iconset>
Then to transfrom the ui file in py file (handling also PySide) just use the small shell script I wrote :
It will fix the path for icons like :
Here following the new zip file:
Have a nice day.
