MACRO:Work Feature 2014_12
felix
Re: MACRO:Work Feature 2014_12
Postby felix » Sun Nov 15, 2015 5:00 pm
Hello. The macro can not be installed in Ubuntu 14.04 Features Work, I tried to git and downloading the file but nothing. I read the installation link, either works for me. Can someone help? Thank you. I installed Drawing_dimensioning and some other but this is nothing impossible.
OS: Ubuntu 14.04.3 LTS
Version: 0.16.5919 (Git)
Build type: None
Hash: 081bc6b10708c244577dd1baf73070be47eb3109
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Félix Fernández
sgrogan
Postby sgrogan » Sun Nov 15, 2015 5:58 pm
WorkFeature is a super macro, like Bolts, so the installation is a little different.
What I do;
From home I clone Rentlau's git repository
https://github.com/Rentlau/WorkFeature.git
then from the created WorkFeature directory in home I copy the WorkFeature sub-directory and the start_WF.FCMacro file to my "home/.FreeCAD" directory.
To update, open a terminal from "home/WorkFeature" directory and
git pull
and then copy and replace the above.
If this doesn't work post back.
Version: 0.16.5924 (Git)
Build type: Unknown
Hash: 629a89218d72d035fde6161eb6247b4bc0f0651d
Qt version: 4.8.6
mario52
Postby mario52 » Sun Nov 15, 2015 6:32 pm
hi
felix wrote:I read the installation link, either works for me. Can someone help?
you must copy alls files in your macro directory ( /home/your_user_name/.FreeCAD ) see Location_and_destination_of_macros
and run start_WF.FCMacro or start_WF.py
see her for create one button on the toolbar Customize_ToolsBar
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
renatorivo
Postby renatorivo » Sun Nov 15, 2015 8:21 pm
note that is visible by clicking on new entry in Combo View
felix
Postby felix » Mon Nov 16, 2015 9:44 am
Sorry I must be stupid.
I have cloned https://github.com/Rentlau/WorkFeature.git in my home directory.
I copied the folder WorkFeature .FreeCAD and start_WF.FCMacro file inside the folder I have also copied .FreeCAD.
Start_WF.FCMacro run and I get this error:
felix felix-sdb @: ~ / .FreeCAD $ python start_WF.FCMacro
File "start_WF.FCMacro", line 16, in <module>
WorkFeature.WF_2015 import as WF
File "/home/felix/.FreeCAD/WorkFeature/WF_2015.py", line 56, in <module>
WorkFeature import from WF_ObjParCurve_2015
File "/home/felix/.FreeCAD/WorkFeature/WorkFeature/WF_ObjParCurve_2015.py", line 5, in <module>
WorkFeature.WF_ObjParCurveEdit_2015 import as ParCurveEdit
File "/home/felix/.FreeCAD/WorkFeature/WF_ObjParCurveEdit_2015.py", line 16, in <module>
as import FreeCAD App
ImportError: No module named FreeCAD
felix felix-sdb @: ~ / $ .FreeCAD
FreeCAD open, try customizing and Macros only see start_WF.FCMacro, which is the file that was copied outside the WokFeature folder.
Sorry Mario, but I do not want to bother appreciate your detailed help.
Felix
renatorivo
Postby renatorivo » Mon Nov 16, 2015 10:57 am
it's strange, my installation is equal to yours, no errors:
Build type: None
Qt version: 4.8.6
with the version 2015_10_05 everything works, have you given permission?
felix
Postby felix » Mon Nov 16, 2015 12:09 pm
No, I have not given any permission, I tried to allow a program to run executable file without result.
I'll keep trying. Thank you very much.
Félix
rentlau_64
Postby rentlau_64 » Mon Nov 16, 2015 9:14 pm
The current release from Github is :"2015_11_08"
It seems to me that you do not have in your PYTHONPATH variable the FreeCAD library path:
Insert the following into your "start_WF.FCMacro" python file just after line 3 :
if not sys.path.__contains__("/usr/lib/freecad/lib"):
    sys.path.append("/usr/lib/freecad/lib")
You must change "/usr/lib/freecad/lib" by your own FreeCAD lib path to import FreeCAD.
To find this path launch "freecad" into an Xterm.
You must see the following line inside the information printed:
'icon': '/usr/lib/freecad/Mod/plugins/icons/master.png',
means that your path should be "/usr/lib/freecad/lib".
Your "start_WF.FCMacro" file must looks like :
# -*- coding: utf-8 -*-
import sys
import os.path
try:
    # try import
    import WorkFeature.WF_2015 as WF
except:
    # get the path of the current python script
    m_current_path = os.path.realpath(__file__)
    m_current_path = os.path.dirname(m_current_path)
    # check if this path belongs to the PYTHONPATH variable and if not add it
    if not sys.path.__contains__(str(m_current_path)):
        sys.path.append(str(m_current_path))
    # retry import now
WF.myDialog = WF.WorkFeatureTab()
My system:
OS: Ubuntu 14.10
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
Please let me know if it solved your issue...?
Rentlau_64
felix
Postby felix » Tue Nov 17, 2015 9:48 pm
Perfect Rentlau_64.
True, I lacked the PYTHONPATH library.
But there is a small error in the GIT. When cloned creates a folder called WorkFeature and in another with the same name.
You have to remove one, ie there must be a single folder called WorkFeature in .FreeCAD. If not it fails.
We must change the GIT to create a single folder.
Thank you very very much.
felix
Postby felix » Wed Nov 18, 2015 11:19 am
I leave a small tutorial of the steps that I followed through if it helps someone.
How to Install on Ubuntu 14.04.
On the Terminal: (Ctrl+Alt+T)
Install Python dependency grapher:
sudo apt-get install snakefood
cd .FreeCAD
Clone Git:
git clone https://github.com/Rentlau/WorkFeature.git
Close Terminal.
Open your Home directory:
Move on folder .FreeCAD (Ctrl+H) to see hidden.
Open the folder WorkFeature
Copy the file start_WFMacro into folder .FreeCAD
Copy on the desk the folder WorkFeature (has the same name, it is within the above).
Back to the folder .FreeCAD
Delete the main folder WorkFeature
Move the folder we copied to your desktop (WorkFeature) into .FreeCAD directory
With the text editor open the file start_WFMacro (right open with gedit)
Copy and paste the following, overwriting all and save the file:
import sys
import os.path
try:
# try import
except:
# retry import now
In short:
.FreeCAD Folder has to have a single folder called WorkFeature containing all the original files.
And besides start_WFMacro we modified file.
.FreeCAD Inside the folder create a new folder called icons
Copy and paste the icon WF_wf.svg into folder icons
Open FreeCAD
Open menu Tools --> Customize
Press Into menu Macros (1)
Press (2) select start_WF.FCMacro
Type a name (3)
Added icon (4)
Select the folder (5 and 6)
Ok (7)
Select the icon (8)
Ok Button
Press Add
Select Toolbars (1)
Select Macros (2)
Select Workbench (3)
Press New (4)
Type a name (5)
Select your macro (6)
copy it to your macros (7)
Close.
Félix Fernández
Tanks Rentlau_64
