I needed to import Bezier curves from Blender yesterday, so I modified the script mentioned in this post to add this feature.
It may not be really clean code, but it works for me.
Here it is :
#!/usr/bin/env python
freecadfunctions="""#!/usr/env/bin python
#python 2
import FreeCAD,Part
from FreeCAD import Vector
def pointstopoles1D(points):
return zip(*[(FreeCAD.Vector(point[0:3]),point[3]) for point in points])
def pointstopoles(points,cu):
poles=[]
weights=[]
for dontcare in xrange(cu):
poles.append([])
weights.append([])
for i,point in enumerate(points):
u = i % cu
v = i // cu
poles[u].append(FreeCAD.Vector(point[0:3]))
weights[u].append(point[3])
return poles,weights
def mults(npoles,degree,isperiodic=False,bezier=False,endpoint=False):
if isperiodic: #and uniform
multv = (1,) * (npoles +1)
elif endpoint: #quasi-uniform
multv=(degree+1,)+(1,)*(npoles - degree-1)+(degree+1,)
elif bezier:
#what OCC describes as picewise bezier
k = 1 + (npoles -1) / degree
multv=(degree+1,)+(degree,)*(k-2)+(degree+1,)
else: #uniform
multv=(1,)*(npoles+degree+1)
#print '%s deg=%d pol=%d sum=%d' % (multv ,degree, npoles, (sum(multv)-degree-1))
return multv
def importblenderspline(d1,doc=None,name=None,showpoles=False):
import FreeCAD
if name is None:
name = 'Surface' if d1['order_v']>0 else 'Curve'
doc = doc or FreeCAD.activeDocument() or FreeCAD.newDocument()
obj = doc.addObject('Part::Spline',name)
obj.Shape = blendersplinecurve(d1).toShape()
if showpoles:
obj.ViewObject.ControlPoints = True
def importblendercurve(d1,doc=None,name=None,showpoles=False):
import FreeCAD
import Part
if name is None:
name = 'Curve'
obj = doc.addObject('Part::Feature',name)
c = Part.BezierCurve()
c.increase(3)
for i in range(len(d1)):
c.setPole(i+1,FreeCAD.Vector(d1[i]))
obj.Shape = c.toShape()
if showpoles:
def blendersplinecurve(d1):
points=d1['points']
cu=d1['point_count_u']
cv=d1['point_count_v']
degu=d1['order_u']-1
degv=d1['order_v']-1
uperiodic=d1['use_cyclic_u']
vperiodic=d1['use_cyclic_v']
if degv != -1:
poles,weights= pointstopoles(points,cu)
bss=Part.BSplineSurface()
umults=mults(cu,degu,uperiodic,d1['use_bezier_u'],d1['use_endpoint_u'])
vmults=mults(cv,degv,vperiodic,d1['use_bezier_v'],d1['use_endpoint_v'])
if d1['use_bezier_u'] and (sum(umults)-degu-1) != cu or d1['use_bezier_v'] and (sum(vmults)-degv-1) != cv:
raise ValueError#would fail later because of mults and points mismatch
bss.buildFromPolesMultsKnots(poles,umults, vmults,uperiodic=uperiodic, vperiodic=vperiodic, udegree=degu, vdegree=degv, weights=weights)
return bss
else:
poles,weights = pointstopoles1D(points)
bsc=Part.BSplineCurve()
if d1['use_bezier_u'] and degu==3: #blender is doing something very strange
poles=poles[1:]
weights=weights[1:]
cu-=1
if d1['use_bezier_u'] and (sum(umults)-degu-1) != cu: #to many poles,
cu=sum(umults)-degu-1
poles = poles[:cu]
weights = weights[:cu]
try:
bsc.buildFromPolesMultsKnots(poles,umults,periodic=uperiodic,degree=degu,weights=weights)
except:
print umults,' ',len(poles)
raise
return bsc
def spline2dict(spline):
d1={}
for attr in ('order_u', 'order_v', 'point_count_u', 'point_count_v',\
'use_bezier_u', 'use_bezier_v', 'use_cyclic_u', 'use_cyclic_v', \
'use_endpoint_u', 'use_endpoint_v'):
d1[attr]=spline.__getattribute__(attr)
d1['points']=tuple((tuple(p.co) for p in spline.points))
return d1
def selection2dictionary():
import bpy
nurbslist=[]
for ob in bpy.context.selected_objects:
if ob.type == 'SURFACE':
name = ob.name
data = ob.data
if len(data.splines) == 1:
nurbslist.append((name,spline2dict(data.splines[0])))
else:
raise ValueError("Not one spline")
return nurbslist
def selection2curvearray():
import bpy
curvelist=[]
if ob.type == 'CURVE':
name = ob.name
data = ob.data
for s in data.splines:
for p in range(0, len(s.bezier_points)-1):
n = name+str(p)
curvelist.append((n,[s.bezier_points[p].co,s.bezier_points[p].handle_right,s.bezier_points[p+1].handle_left,s.bezier_points[p+1].co]))
return curvelist
def writeFreeCADMacro(nurbslist,curvelist,filename):
outfile=open(filename,'w')
outfile.write(freecadfunctions)
for name,d1 in nurbslist:
outfile.write('importblenderspline(%s,name="%s")\n' % (repr(d1),name))
for name,d1 in curvelist:
outfile.write('importblendercurve(%s,name="%s")\n' % (repr(d1),name))
outfile.close()
if __name__ == '__main__':
writeFreeCADMacro(selection2dictionary(),selection2curvearray(),'importnurbstofreecad.py')
