Draft modifiers recursive calling of recompute when selecting more than 27 document objects
carlopav
Postby carlopav » Sun Feb 09, 2020 5:00 pm
In the attached file, but in general in every document that have many objects.
If I run Draft move or rotate on more than 27 object this error is triggered:
11594.6 <App> Document.cpp(3106): Recursive calling of recompute for document Unnamed
And objects are moved/rotated twice the given quantity.
If instead i toggle skip recompute from the document context menu in the treeview (right click on the document name in the treeview and skip recompute) everything seems to work fine.
What I imagined is that moving lots of objects cause many recomputes and this is not good, so perhaps we should disable recomputing during commands execution. But how? In the Todo function?
EDIT: the bug is not present in 0.18.4, while confirmed in :
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19510 (Git)
Hash: c3eb6d9001c4d60ff7f7cae89f50bd3c965a9940
Python version: 3.6.8
Qt version: 5.12.1
Locale: Italian/Italy (it_IT)
Bug Draft move recursive calling of recompute.FCStd
(85.65 KiB) Downloaded 1 time
bitacovir
Re: Draft modifiers recursive calling of recompute when selecting more than 27 document objects
Postby bitacovir » Sun Feb 09, 2020 11:05 pm
Qt version: 5.12.1
Similar reports in this thread https://forum.freecadweb.org/viewtopic. ... ve+calling
::bitacovir::
My Blog
Mini Airflow Tunnel Project
carlopav
Postby carlopav » Tue Feb 11, 2020 5:12 am
Yes that's similar and quite annoying.
I don't know if it's something I introduced or something that changed in freecad and we should consider in Draft... I'll make some more tests thesedays...
Anybody that I could eventually ping for help?
vocx
Postby vocx » Tue Feb 11, 2020 6:21 am
This is most probably a realthunder bug.
He already submitted various pull requests with tons of small fixes, so maybe one of those commits solves this. The problem is those pull requests have been sitting in the queue for several weeks now.
Postby yorik » Wed Feb 12, 2020 12:36 pm
We are busy processing realthunder's PRs. But some are quite complex so it takes time. (It always helps if someone is willing to test and give feedback on the PRs, just to say that it works)
bitacovir
Postby bitacovir » Thu Feb 13, 2020 7:51 pm
No idea how to do that. I just wait for the next development version release.
::bitacovir::
My Blog
vocx
Postby vocx » Fri Feb 14, 2020 1:07 am
First set up your own fork, and your own remote (origin and upstream) repositories, as indicated in Source code management.
Then you can test somebody else's branch. We assume we are in the "source" directory where we initially downloaded (cloned) our repository.
0. Optionally, we can use the "gitk" program to visualize the branches and commits. This gives a better idea of all commits made in the checked branches. We use the ampersand symbol to run "gitk" in the background so we don't block the terminal and can run other commands.
gitk --branches &
In "gitk" press Shift+F5 to reload the database of branches.
1. Add realthunder's repository as a remote
git remote add realthunder https://github.com/realthunder/FreeCAD
2. Fetch the information in his repository to know the available branches.
git fetch realthunder
3. Now, make sure you are in the master branch, and then create and checkout the specific branch that is indicated in the pull request in your local system. Example, pull request #3045.
git checkout master
git checkout -b DressUpTransform realthunder/DressUpTransform
4. Optional: that branch may not be based on the latest code in the upstream repository, so we could rebase it ourself to make sure it is using the latest code.
git pull --rebase upstream master
If there are any conflicts, they will appear at this step; these conflicts in the code in realthunder's branch will have to be solved before continuing (this requires a bit of experience and actually understanding the code).
5. If there are no conflicts and everything seems to be okay, we can proceed with compiling.
6. In Linux, we move to the build directory and compile the source.
cd ../freecad-build
cmake -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 ../freecad-source
make -j3
7. If the branch introduced only Python code, the compilation will be very fast, and it should finish after three minutes or less. If the branch modified C++ code, it may take a long time depending on the type of code that was introduced. If core files were created or modified, it may take up to two hours to recompile and link everything.
8. After the compilation is done, the new generated executables are inside the bin/ directory. Launch the program and test that everything works fine; also perform the unit tests.
bin/FreeCAD
bin/FreeCAD -t 0
9. Report your findings. "This branch is great and fixes the problem." "This branch fixes this but breaks that which was working before."
bitacovir
Postby bitacovir » Fri Feb 14, 2020 11:30 am
Thank you Vocx for this complete instruction. I had a remote repository, but later my laptop went a mess and I had to run a hard reset and delete all. I will see if I can reinstall a repository again. But if the process of checking pull requests requires reading or understanding the code, I could not help.
::bitacovir::
My Blog
vocx
Postby vocx » Sat Feb 15, 2020 2:29 am
...But if the process of checking pull requests requires reading or understanding the code, I could not help.
If you just checkout a branch it should not cause a conflict. You should be able to compile it as is, as long as you have all dependencies and follow the instructions in Compiling. Well, also assuming that the author of the branch wrote the code correctly.
It is only when I do the optional step of "rebasing" that a conflict may appear. This conflict you have to solve yourself, or rather, it has to be solved by the author of the branch when he or she makes the pull request against the master branch.
Once in a while you have to update your own master branch, otherwise your copy of the source code gets too old.
git checkout master
git pull upstream master
So, in general, testing a branch shouldn't be too big of a problem. Just follow my instructions, compile, and use the program.
