specify document in Arch make methods
Postby bernd » Mon Sep 14, 2020 7:18 am
Just realized in Arch it is not possible to parse the document the object is created in if use Arch.makeSomeSmartArchObject(parameters). The active document is used for all Arch make methods.
Mhh IMHO in no document is given the active should be used. For robustness it would makes sense to parse the doc the object is created in, would it not?
ATM I need to explizit set the ActiveDocument with the doc object I would like object to be created in. If not I get a miss match if creating documents objects inside the document and closing the document in a loop.
cheers bernd
vocx
Re: specify document in Arch make methods
Postby vocx » Mon Sep 14, 2020 10:13 pm
... For robustness it would makes sense to parse the doc the object is created in, would it not?
Do you mean something like this?
doc1 = App.openDocument("Doc1")
doc2 = App.openDocument("Doc2")
Arch.make_something(doc1, args)
Arch.make_something(doc2, args)
I have thought about this as well, however, no code that I've seen in Draft, Arch, or BIM does it. It always assumes the active document.
So, changing this would mean refactoring the entire programming interface which would take a while, and could potentially break things.
The easiest thing that I can think about is adding an additional argument at the end to consider the document.
def make_something(args, doc=None):
    if not doc:
        doc = App.activeDocument()
Postby bernd » Tue Sep 15, 2020 10:02 am
exactly.
In FEM all make methods have a document parameter. In FEM it is at the end, which is cumbersome if you would like to use the active document, because you need to add it all the time. But IMHO better than no doc parameter.
I am curious what others think about this.
vanuan
Postby vanuan » Wed Sep 16, 2020 7:54 am
You're reading my mind :)
Yes, this is very much needed. For compatibility reasons, you have to make the document optional, but in reality, you can't create objects outside the document, can you? C++ defines "addObject" function as a method of a Document.
Maybe similarly Python should have it's own DocumentProxy?
E.g.
class DocumentProxy:
  def __init__(self, doc):
      if not doc:
        raise Error("No active document. Aborting")
    self.doc = doc
  def addObject(self, proxy_class, arguments, name, cpp_type = 'Part::FeaturePython'):
    obj = self.doc.addObject(cpp_type, name)
    proxy_obj = proxy_class(obj)
    obj.Proxy = proxy_obj
    return obj
def makeWall(doc, *args):
  wall = doc.addObject(_Wall, args, 'wall', )
but maybe that's complicated. A simple additional parameter would do.
Postby bernd » Wed Sep 16, 2020 9:32 am
FYI: you can not create document objects outside of a document, but in Part one can create shape objects without the need to create a document object. Arch, Draft and most FEM objects do not support this either. But this is a totally different story even more complicated to change.
Postby yorik » Mon Sep 21, 2020 1:31 pm
I agree with that as well. vocx's solution seems the easiest, to maintain backwards compatibility...
