OS: Debian GNU/Linux bullseye/sid (XFCE/xfce)
Version: 0.19.23964 (Git) AppImage
Hash: db9525e7d78c956df96dd6db2c52f20a50a2aa5f
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
snapRange : I cannot find that using the path you have given, the ones I get beginning with snap are; snapcolor, snapModes, snapStyle.
I cannot get the [ and ] to do anything either.
DraftEditPickRadius : This appears to be the number that can also be controlled using View -> Preferences >> Draft >> Grid and snapping. On this page the number is limited from 0 to 99. Going via the Edit Parameters route you can set a negative or greater than 100, it seems to store it, however if you subsequently look at it via the View -> Preferences route, negatives become 1 and numbers greater than 100 become 99 and the DraftEditPickRadius is updated in the parameters.
DraftEditPickRadius appears to not change the snapping, however however I would read the name as the closeness the pointer needs to be to select something, which could be different to the snap distance. That said altering it, does not seem, to alter the distance for selection.
