I confirm this bug for FC 0.19.24267
Have this regression been reported to the Bugtracker?
https://tracker.freecadweb.org/
I cannot find a issue referred to this. If not, I'll report it.
OS: Windows 10 (10.0)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Move wall with doors and/or windows
Re: Move wall with doors and/or windows
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
There have been many posts about this, including one from me, https://forum.freecadweb.org/viewtopic.php?f=23&t=53491bitacovir wrote: ↑Mon Mar 08, 2021 12:19 am I confirm this bug for FC 0.19.24267
Most of the posts have gone unsolved, but I agree that it appears that no bug has been reported. I didn't at the time as I was only beginning my use of FreeCAD, however, Ive been using sketches to place walls, and as the sketch moves the windows don't. I never used 0.18 so had sort of assumed it was a feature yet to be implemented.
I went through this bug and while we are waiting to be solved, we can follow these suggestions:AndrewA wrote: ↑Mon Mar 08, 2021 9:46 pmThere have been many posts about this, including one from me, https://forum.freecadweb.org/viewtopic.php?f=23&t=53491bitacovir wrote: ↑Mon Mar 08, 2021 12:19 am I confirm this bug for FC 0.19.24267
1) Lets to consider as not good practice the movement of many walls, in a workflow. Ideally, use several working planes for each level of a building and place the walls in their final position.
2) Use Menu Edit - Placement to move walls that contain windows (select all objects - setup position with Placement, check Apply Incremental box).
3) Create separate groups of walls (levels) in different files and place them in a new file with Arch External Reference (for each element: wall, window). Later you can put them in a Arch Floor container and move it.
::bitacovir::
::bitacovir::
Hey just a note that I've worked around this by placing the group of objects I want to move in a [Part]. I had thought that an Arch [Building Part] might do the trick, but that container doesn't have an origin, so threw the lot (wall, 2 x windows, these three in a [Building Part]) into a [Part] and moved the [Part] with Draft Move.
I'm not doing anything so useful as solving the bug, but here's something that works... ref attached.
- test-01.FCStd
- (110.64 KiB) Downloaded 26 times
