[ Fixed ] Draft Text: Text not aligned with working plane
Roy_043
Post by Roy_043 »
The Draft Text command does not fully respect the current working plane.
Test:
  1. Open the attached file.
  2. Align the Draft workingplane (Draft_SelectPlane) with the face of the box marked with the circle.
  3. Start the Draft_Text command.
  4. Enter 0,0,0 in the local coordinate system.
  5. Result: The coordinates in the LCS are used but the text is aligned with the XY plane of the GCS. See 'Test' text in the image.
If you do the same with the Draft_ShapeString command you will see that coordinates can only be entered in the GCS, but the alignment of the XY plane of the LCS is used. See 'Default' text in the image.
Also compare the Draft_Dimension command which does fully respect the working plane.
draft-text-test.FCStd
(20.64 KiB) Downloaded 80 times
thomas-neemann
Re: Draft Text: Text not aligned with working plane
Post by thomas-neemann »
Roy_043 wrote: Wed May 12, 2021 2:02 pm
i know you're not looking for a workaround, but here's one for anyone interested. 1 min
https://www.youtube.com/watch?v=hdnZMt_sy7A
phpBB [video]
Roy_043
Post by Roy_043 »
Roy_043
Re: [ Fixed ] Draft Text: Text not aligned with working plane
Post by Roy_043 »
Merged.
thomas-neemann
Roy_043 wrote: Fri Oct 08, 2021 11:29 pmMerged.
it works. Thanks very much
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26155 (Git) AppImage
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
