Snap to the Center of a BuildingPart: how does that work?
Roy_043
Postby Roy_043 » Wed Jul 21, 2021 10:27 am
According to the Draft_Module page you can snap to the center of a BuildingPart. I wonder how that works.
I am unable to snap to a BuildingPart containing a single wall in Wireframe mode if only Center snap is active. And I have to switch to Wireframe mode to prevent snapping to faces.
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
marioalexis
Re: Snap to the Center of a BuildingPart: how does that work?
Postby marioalexis » Wed Jul 21, 2021 1:12 pm
The snap to BuildingPart works with Snap Center: https://github.com/FreeCAD/FreeCAD/pull/4410
You can also set Selectable to false in the object's view properties if there is interference between snapping.
Roy_043
Postby Roy_043 » Wed Jul 21, 2021 3:09 pm
Thanks for your comment. I am aware that Center snap should work for BuildingParts (see the linked page in the OP). Perhaps I am doing something wrong, but I cannot get it to work at all.
Direct link to the code:
https://github.com/FreeCAD/FreeCAD/blob ... er.py#L467
marioalexis wrote: Wed Jul 21, 2021 1:12 pm set Selectable to false
You would have to do that for the objects inside the BuildingPart then. But even then it does not work. And AFAICT snapping to objects that are not selectable is impossible.
If you can get it to work then please provide step-by-step instructions.
marioalexis
Postby marioalexis » Wed Jul 21, 2021 11:33 pm
I guess we are doing the same (unless I misunderstood your first post). In any case, here are the steps:
Create a BuildingPart
Create ArchWall inside the BuildingPart
Set Snap Center to ON
Select some Draft Modification or Creation command.
Try to snap the BuildingPart.
Roy_043
Postby Roy_043 » Thu Jul 22, 2021 6:36 am
Ah, thanks for that! I was clicking on the edges of the wall and did not consider the text element and the 3 axis lines of the BuildingPart.
BTW:
Using Center snap for this, and for snapping to WP proxies, is a bit confusing IMO. Wouldn't it make more sense to extend Draft_Snap_Special instead?
paullee
Postby paullee » Thu Jul 22, 2021 1:42 pm
Good to learn that :)
And agree that better be Snap Special.
