Structure in xz-plane
rockn
Re: Structure in xz-plane
Postby rockn » Sat Dec 26, 2015 12:21 pm
To get the normal automatically my workflow is the following :
Draw a Draft/Dwire on whatever working plane.
Set the Make Face property of the Dwire to true.
Select the face and use Draft/Trim to make an extrude (the extrude will be normal to the face and you can choose the direction).
Then I create a structure from the Extrude object.
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
JAndersM
Postby JAndersM » Sat Dec 26, 2015 4:42 pm
Ok!
That gave me an idea. I checked the code for Draft extrude and then I changed the line 607 in ArchStructure.py to replicate the one that is used in DraftTools, normal=obj.Base.Shape.Faces[0].normalAt(.5,.5) :
                if not base:
                    if not height:
                        return
                    if obj.Normal == Vector(0,0,0):
                        #Old line p = FreeCAD.Placement(obj.Base.Placement)
                        #Old line normal = p.Rotation.multVec(normal)
                    else:
                        normal = Vector(obj.Normal)
Now Structures work for Circles, Rectangles. Polygons and also b-splines and closed DWires in the same way. Extruding normal to the face by default.
Might be useful for others as well. (If there’s no adverse effects that pops up!)
