Using Arch SectionPlane on imported Iges format geometry
bitacovir
Postby bitacovir » Wed Feb 03, 2016 10:45 am
I imported a geometry (hinge) with iges format into a project where I am working. I did it as iges format because I do not know hot to import FCStd files into another project.
My problem is when I use Arch SectionPlane, I can not create a Draft Shape2DView of the iges format object.
OS: Windows 7
Version: 0.16.6348 (Git)
Hash: 5fbdd4ac6624e32ba3a3e5523a31d56fe3ba7ae6
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
::bitacovir::
My Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Re: Using Arch SectionPlane on imported Iges format geometry
Postby yorik » Wed Feb 03, 2016 12:59 pm
Is there any error message? Can you share the iges file?
sgrogan
Postby sgrogan » Wed Feb 03, 2016 5:51 pm
bitacovir wrote:I imported a geometry (hinge) with iges format into a project where I am working. I did it as iges format because I do not know hot to import FCStd files into another project.
I take it that you exported the hinge to iges from FreeCAD?
If so make sure Enable B-REP mode is checked in preferences before exporting.
Edit > Preferences > Import/Export > iges tab and check the box.
To import the .FCstd file directly use File > Merge Project...
bitacovir
Postby bitacovir » Thu Feb 04, 2016 5:06 am
sgrogan wrote: I take it that you exported the hinge to iges from FreeCAD?
Thanks sgrogan. That was the problem. And now I can work with FCstd, too. Funny but I thought I was not possible to import a FCstd because I saw a tutorial saying that and suggesting to open this file and to export it as iges for import.
::bitacovir::
My Blog
