arch roof tool - geometry errors
JLB85FR
Postby JLB85FR » Tue Mar 15, 2016 7:18 pm
when creating a simple roof from a rectangle, all the roof parts are detected in error with the part 'Check geometry' tool.
is this normal or not ? look at attached design. I just changed the 'run' values to 500mm.
thanks
roof with geometry errors.FCStd
(9.37 KiB) Downloaded 62 times
Renato Rebelo
Re: arch roof tool - geometry errors
Postby Renato Rebelo » Tue Mar 15, 2016 10:27 pm
Which version you use?
You should join information about the version of FreeCAD ...
I tested the file and everything seems to be fine ...
greetings,
Renato
OS: Ubuntu 15.10
Version: 0.16.6623 (Git)
Build type: None
Hash: 9d617ce4c8a0d65155c6b2d4bbff273519b6e573
Python version: 2.7.10
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
JLB85FR
Postby JLB85FR » Tue Mar 15, 2016 11:04 pm
sorry, this is a derivation of another topic I made. not tested with 6623...
OS: Windows XP
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6612 (Git)
Hash: 18f0cc634665e15f5191dbfa9ea980a16e25ad26
Python version: 2.7.8
Qt version: 4.8.6
JLB85FR
Postby JLB85FR » Tue Mar 15, 2016 11:17 pm
I've just downloaded the last release:
OS: Windows XP
Qt version: 4.8.6
same problem. did you checked on roof ? not base rectangle ?
I'll try on osX later ....
roof geometry errors.PNG (24.8 KiB) Viewed 1984 times
Renato Rebelo
Postby Renato Rebelo » Tue Mar 15, 2016 11:42 pm
Yes, I tested the roof, not detected any errors?
greetings,
Renato
rockn
Postby rockn » Wed Mar 16, 2016 12:18 am
Hi JLB85FR,
You're right, the BOPAlgo check failed. And it's not normal.
It's because the roof object is a compound of solids (one for each pane), if you downgrade the object you will get valid solids.
I notice a fusion of these solids give a valid object.
I will look into the code.
@renato : You have to enable the BOPAlgo check :
Tools>Edit parameters>BaseApp>Preferences>Mod>Part>CheckGeometry>RunBOPCheck>True
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
Renato Rebelo
Postby Renato Rebelo » Wed Mar 16, 2016 11:11 pm
OK,
already tested and detects errors,
thank you,
Renato
JLB85FR
Postby JLB85FR » Thu Mar 17, 2016 7:24 pm
Thanks guys for your tests.
I tried the downgrade, it makes first a compound that needs to be downgraded in turn, but after that, it is not possible to undowngrade (upgrade) ... I think.
I used CTRLZ to rollback, from the fusion, all was ok until the compound, but I didn't find the original roof again. it appears in the treeview, but is not visible (seems to have been reduced to a zero size).
Of course, the idea is to continue working with roofs... to be able to adjust its properties.
it will be nice if you find something in the code, rockn.
BTW, I have tried to make a roof with only one pane, I never succeed really (there is still one line beeing visible on one side)
roof vanished after undo downgrade.PNG (16.05 KiB) Viewed 1886 times
rockn
Postby rockn » Fri Mar 18, 2016 12:29 pm
The BOPCheck failed is fixed now : git commit 010121d8c11a4cbdcaaf14d476f501108ad5f7f4
The final roof objet is a fuse.
About Ctrl-Z/undo failed I need more time, not sure it will be done until 0.16 release.
To make a one pane roof, make wire with 4 edges, create a roof, set 3 panes with an angle of 90°.
jmaustpc
Postby jmaustpc » Fri Mar 18, 2016 4:04 pm
rockn wrote:Hi,
Hi Rockn
I have worked out one thing that had been causing me to not get a valid roof. My roof was upside down. If I create a rectangle in a sketch, it would seem that you must start at the bottom left corner and drag to the top right, if you go from top right down to bottom left you get a plane normal in the wrong direction, the same is true for a roof based on a Draft Rectangle.
this file shows what I am talking about, the last roof is upside down.
ArchRooftests1.fcstd
(28.97 KiB) Downloaded 39 times
Jim
