arch roof tool - geometry errors
rockn
Re: arch roof tool - geometry errors
Postby rockn » Fri Mar 18, 2016 5:31 pm
Hi Jim,
It's because of conterclockwise direction. Cf : Arch_Roof #How_to_use
In Sketch002_br to tl geometry are clockwise direction.
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
JLB85FR
Postby JLB85FR » Fri Mar 18, 2016 7:43 pm
Hi Rockn
nice for BOPCheck !
rockn wrote:To make a one pane roof, make wire with 4 edges, create a roof, set 3 panes with an angle of 90°.
I think that I already tried to set 3 panes with 90 degrees angle, but I had problems it had abnormal behavior, but at this time I just changed these properties in 2 designs were they were not correct and it works fine.
I don't understand why it was not working, now all is ok... :)
thanks for the tip anyway.
NormandC
Postby NormandC » Sun Mar 20, 2016 5:31 pm
jmaustpc wrote:If I create a rectangle in a sketch, it would seem that you must start at the bottom left corner and drag to the top right, if you go from top right down to bottom left you get a plane normal in the wrong direction
Now why would you do that, is that normal for down unders? :mrgreen:
jmaustpc
Postby jmaustpc » Sun Mar 20, 2016 11:34 pm
Of course, perfectly normal down here in upside down tomorrow land! Should seem normal to you to, being a weird "cacky handed" "lefty" :lol:
