Using Yorik's SweetHome3D importer
Should be mentioned that:
1) You need the 'Export to HTML5' plugin for Sweethome3D.
2) This produces a zip file <Building name>.zip. This file will not work. it contains (among other things) a file also called <Building name>.zip. This is the one you need.
Reason: fixed typo in thread title
Re: Using Yoric's SweetHome3D importer
Welcome to the forum! Thanks for your comments!
I'm not familiar with that plugin, but I guess that 1) needs to go into our wiki documentation and 2) is a bug (zip in zip)?
The plugin was only released on May 5th, so it's still in early stages.
Wow you're fast!
Yes, it's still very early, and I'm discussing with the sweethome3d people, so there might still be changes (on their side too), so I didn't want to advertise something that could change afterwards.
But since we are there now...
- you need sweethome3d >= 5.2
- you need the OBJ/XML plugin from http://www.sweethome3d.com/plugins/Expo ... J-1.1.sh3p
Otherwise the zip produced will not contain the walls as XML. With this plugin, there is only one zip produced, not a zip in a zip.
The walls get imported reasonably well, but there are some problems because in sweethome3d it is hard to make endpoint coincidents. So walls often import with bad geometry. This is often solved by editing the sketch that is the baseline of walls, and add a "point-to-point" constraint on coincident points.
The geometry of windows get turned into shapes, which can produce some crappy invalid shapes.
The furniture works well already, but they are still meshes, not sure yet about what to do with them next.
Linking issue #2584
I've had trouble importing SweetHome3D exports into FreeCAD. In SweetHome 3D, the original file has four levels, four feet apart vertically (it's a split level house).
Exporting from SweetHome3D via Tools | HTML5 and importing as SweetHome3D .zip file yields nothing.
Exporting via Tools | XML/OBJ and importing as SweetHome3D .zip file yields all levels at the same elevation, and horizontally misplaced windows and doors.
Brian
Later, I updated the SweetHome3D Export XML/OBJ plugin to 1.3, with results identical to the original 1.1 plugin. ( I got it from here: www.sweethome3d.com/plugins/ExportToXMLOBJ-1.3.sh3p)
Brian
Re: Using Yorik's SweetHome3D importer
Just wanted to report that I tried the export/import procedure from sh3d to freecad and experienced some problems.
Most things seems to have been mirrored, and the wall, door and window elements are not placed correctly. The shades seems to not have been mirrored.
Screenshot from sh3d before export: Screenshot from freecad after import: Using the same plugin (www.sweethome3d.com/plugins/ExportToXMLOBJ-1.3.sh3p) as been linked previously in this thread.
OS: Ubuntu Impish Indri (development branch) (ubuntu:GNOME/ubuntu)
Version: 0.20.25645 (Git)
Build type: Unknown
Python version: 3.9.6
Qt version: 5.15.2
OCC version: 7.5.1
Build type: Unknown
Qt version: 5.15.2
OCC version: 7.5.1
Made some more observations,
After messing around a bit in the document tree, I got some sub shapes of doors and windows visible in almost the right position: But it seems like all objects are anchored to the "ground plane": Also some of the wall lines are a bit off:
Nice!laschrocket wrote: ↑Mon Sep 06, 2021 8:57 am After messing around a bit in the document tree, I got some sub shapes of doors and windows visible in almost the right position:
I'll notate issue #2584
Can we use git to track/merge your changes so far?
- ragohix769
Very interesting.
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
