FreeCAD 0.17 and Arch Window
A forum dedicated to the Arch and BIM workbenches development.
damian
Postby damian » Wed Sep 14, 2016 8:54 am
OS: Ubuntu 14.04.5 LTS
Version: 0.17.8405 (Git)
Build type: None
Hash: 05a25967bd756405a688526f4b63c5fad6e71378
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Good morning
The Arch's presets are working well in FreeCAD 0.17. There is a curious thing with the windows.
1º) I've drawn a wall, which is not parallel to X axis
2º) I try to draw a window and I have two situations:
if I move the cursor down and left all is correct
if I move the cursor up and right the window takes a mistake normal
This is the end result
If the wall is 'wireframe', in all situations the normal is wrong
Frequently, I like to draw the windows from scratch, and in FreeCAD 0.17 I am having problems.
In this last case, the normal is correct but the window takes the placement of the base sketch, when the window's placement must be angle 0 axis (0,0,1) position (0,0,0). And it doesn't also execute the removeComponents.
Running the Python command 'Arch_Window' failed:
File "/usr/lib/freecad-daily/Mod/Arch/ArchWindow.py", line 432, in Activated
FreeCADGui.doCommand("host=Arch.make"+Draft.getType(host)+"(FreeCAD.ActiveDocument."+host.Name+")")
File "/usr/lib/freecad-daily/Mod/Draft/Draft.py", line 171, in getType
if "Proxy" in obj.PropertiesList:
'list' object has no attribute 'PropertiesList'
am I loosing anything?
Thank you
damian
Re: FreeCAD 0.17 and Arch Window
Postby damian » Wed Sep 14, 2016 12:58 pm
About making windows from scratch, in FreeCAD 0.16
>>> sketch.Support
(<Part::PartFeature>, ['Face1'])
in FreeCAD 0.17
>>> sketch.Support
[(<Part::PartFeature>, ('Face1',))]
lines 415 to 418 in ArchWindow.py
damian
Postby damian » Wed Sep 14, 2016 1:12 pm
and making the window from scratch with a Draft rectangle, in FreeCAD 0.17
in FreeCAD 0.16 this operation works fine
yorik
Site Admin
Postby yorik » Fri Sep 16, 2016 2:39 am
Hm indeed some bugs seem to have appeared when creating windows from a sketch, I'll look into it...
But for your first problems, everything seems normal here, I think you probably didn't snap correctly to the face. Try enabling the "nearest" snap, usually it works better
damian
Postby damian » Fri Sep 16, 2016 12:39 pm
yorik wrote:But for your first problems, everything seems normal here
It does not a problem. I commented it because it seems curious.
The issue seems to be that I define the wall's face as working plane (I was drawing something in the face). If I maintain the original working plane (xy), the mechanism is much more precise. Please, forget it.
yorik wrote:some bugs seem to have appeared when creating windows from a sketch
Yes, the improvements in the sketcher module. This really is important.
Thank you
damian
Postby damian » Sun Sep 18, 2016 9:06 am
Good morning:
I would like to do a more regulated description of the problem "creating a window from scratch in FreeCAD 0.17".
The steps to reproduce the 'bug' are included in Window's wiki page (http://freecadweb.org/wiki/index.php?title=Arch_Window):
Creating from scratch
Optionally, select a face on the Arch object where you want the window to be incuded
Switch to the Sketcher Workbench
Create a new sketch
Draw one or more closed wires
Close the sketch
Switch back to the Arch Workbench
Press the Arch Window.png Arch Window button, or press W then I keysquote
The problems are two:
1º) when the new window object takes its base object in ArchWindow.py line 67
obj.Base = baseobj
it also copy the baseobj.Placement, resulting a window with mistaken Placement.
I would like to propose doing
obj.Base = baseobj
pl = FreeCAD.Placement()
obj.Placement = pl
2º) when the windowCommand executes removeComponent in ArchWindow.py line 439, it looks for a Tuple in line 415, but finds a List, resulting that the remove command is not executed
if isinstance(obj.Support,list):
    host = obj.Support[0][0]
This two patch are working fine for me, for the moment ...
By
yorik
Site Admin
Postby yorik » Mon Sep 19, 2016 7:12 pm
I don't like much your first idea, because, if, for example, you draw a sketch on a wall, if you do that, the window will not be placed on top of the sketch. I actually don't see what case this would be fixing?
Your second proposal I just added in git commit 008fed6.
damian
Postby damian » Tue Sep 20, 2016 8:46 am
yorik wrote:I don't like much your first idea
me too ...
Renato Rebelo
Postby Renato Rebelo » Tue Nov 22, 2016 10:45 pm
damian wrote:and making the window from scratch with a Draft rectangle, in FreeCAD 0.17
Hello Yorik
I can confirm that the sketch-based window location bug remains :(
Renato
OS: Ubuntu 16.04.1 LTS
Version: 0.17.8972 (Git)
Build type: None
Hash: 14594dde32d3af23d496a0b630db18480e618249
Python version: 2.7.12
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
yorik
Site Admin
Postby yorik » Thu Nov 24, 2016 8:37 pm
Renato Rebelo wrote:I can confirm that the sketch-based window location bug remains :(
Hopefully this should now be fixed with git commit 6b8b3ec
