is there a possibility to turn a window or a wall 180° on its own z-axis?
The reason is, put some doors from the wrong side, so it looks like the door opens in the wrong room.
regards
tux
turn window 180°
turn window 180°
- door.PNG (4.57 KiB) Viewed 895 times
Re: turn window 180°
You can actually simply just rotate the window 180° with Draft rotate or by modifying the placement, that should "just work"...
It is on my TODO list to find a way to add door/window opening symbols, and then windows will be aware of their opening direction. Then it should be relatively easy to implement something to flip them, like revit.
