I'm trying to use spreadsheet contain footing parameter.
when try to change a new value on the spreadsheet(named ControlParam),the model will change.
I used PartDesign to contain concrete and rebars for control position and rotation of footing's element group.
change parameters on Spreadsheet
Sample File for test.
Test Parametric Footing using Spreadsheet control parameters(no python script)
Re: Test Parametric Footing using Spreadsheet control parameters(no python script)
Add rebar in y-direction
Used Draft element(Rect , Line , Dim) to show TopView
Sample File version 0.2
