paullee wrote:yorik wrote:
So far that is all it does. But it will be easy to extend all other functionality (Techdraw Arch view, etc) to support this, it's just a matter of using a shape instead of another. The Arch OBJ exporter already uses this, if one of the to-be-exported objects is in Hires display mode, the Hires shape will be exported instead of the base one. This also works with Arch clones, if the cloned object has a Hires shape, you can use the Hires display mode on the clone too.
Reading again the first post, I would vote for the following features for which I used most:)
- Array
- Mirror (+ Mirror on MIrror) (maybe Scale)
- Alias Obj Exporter (sorry I reported earlier some issues about Arch OBJ exporter which is though terrific to calculate coplanar surface)
- TechDraw / ArchSectionPlane
... 'Bug' fix on PartComponent? I am thinking of workaround for the time being
Definitely very helpful for project with repetitive or even repeating with variations construction!
(I am thinking to organise those repetitive arrangement in an schedule ...)
Hi, I am experimenting my idea to re-arrange my model from bottom to further streamline the workflow and file size (trying Arch Component & Spreadsheet on which I have some problem posted in Help Board) and have some finding and feature request:-
Findings
1. I build an arbitrary Arch Component, then I can refer the Arch Component (Arch Wall etc. in fact) X, Y, Z to a Spreadsheet Cells, without needs to give Alias to the cells. In this wall, my facades (precast) type could be built and the layout of them be presented both based on a spreadsheet - at least the idea on a simple trial version of 3 storey of a facade works.
2. Each Clone of the Arch Component, could in fact, refer to different Hi-Res!!! This could make the Arch Component only a 'placemarker' / 'reference' whatever you like to name it, and I could refer the Hi-Res to different Precast Facade types I have for every storey, every elevation!
Feature Request
3. To achieve idea in point 2 above, I need to select the correct ArchWall (Precast Facade type). It is a long list (see screenshot which show maybe 1/20 of them).
3a. It would be very helpful if the Hi-Res field could also use Formula Expression and I refer it to a Cell in the SpreadSheet, so ideas both in Point 2 as well as Point 1 could be achieved at the same time! (e.g. in this field "=Spreadsheet.F18" / in Spreadsheet.F18 "Facade Type 009" - [internal] name of the object)
3b. For the Hi-Res dialog box, it would be helpful if the listing be organised, e.g. selection by alphabetical, FC object type category, filter etc.
EDIT: (found there is Search function)
Regards.
p.s.
I notice Yorik you used both Part Component + Arch Component in your Wikihouse - any reason for the choice?
- Screenshot from 2017-05-07 01-49-55.png (289.58 KiB) Viewed 2754 times
OS: Linux
Version: 0.17.10997 (Git)
Build type: Unknown
Hash: 37a62b4096d7fbfc5295259bcd7977cb713868f8
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
