There is a strange effect on the current roof tool
According to this tutorial the sketcher base drawing should normaly generate a roof that is vertical upright in a normal direction
the 3rd picture shows the normal way that the roof should be generated by the sketch base, as show in the tutorial, but in this instance this roof is normally generated by the Draftwire base
the 2nd picture shows the same roof done with the sketcher, and it generated and inverted roof,
This is not in it self a bad option to generated a roof like shape upside down, but an addition optional option to control the Normal could be added if possible?
the 1st picture is from freecad 0.15, it seems even the older version has the same problem.
OS: Linux Mint 18.1 Serena
Version: 0.17.11266 (Git)
Build type: None
Hash: ab1b344410600b7d694abf6bb4ff2b71769978c5
Python version: 2.7.12
OCC version: 7.1.0
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.11
OCC version: 6.8.0.oce-0.17
Roof inverted from Sketcher base drawing
- this picture shows the normal way that the roof should be generated by the sketch base, as show in the tutorial, but in this instance this roof is normally generated by the Draftwire base
- Screenshot from 2017-06-12 20-03-28.png (176.85 KiB) Viewed 1814 times
- this picture shows the same roof done with the sketcher, and it generated and inverted roof
- Screenshot from 2017-06-12 20-00-18.png (215.74 KiB) Viewed 1814 times
- Screenshot from 2017-06-12 19-59-32.png (203.74 KiB) Viewed 1814 times
- kkremitzki
Re: Roof inverted from Sketcher base drawing
These can be embedded into the post like so:regis wrote: ↑Tue Jun 13, 2017 12:12 am https://www.youtube.com/watch?v=Rl3INyzi5IM
https://www.youtube.com/watch?v=BzO4YphRGX8
Probably the normal direction is wrongly estimated by the roof tool. Maybe the best way would be to do the same as other Arch tools, allow the user to fix the normal direction. I'll look into it.
Hi
I had the same problem.
It was using a rectangular scketch, but when using polylines (in counter clock wise disposition - didn't try another way?) the roof behavior is OK.
This was tested using regis explained technic for using sketches to constraint arch roof, wall, slab ,...
Cheers
Cheers
