hhassey wrote: ↑Fri Jan 05, 2018 8:23 pm
... to make sure the end result was composed of only solids.
Good idea!
Some profiles are not fixed together, the frame could collapse
But the FEM-analysis works, I got no errors when meshing and running calculix.
You see the deformation/stresses under vertical loading with 500 kg, distributed
along the upper beam. I used the predefined values from your macro to generate the geometry.
You can do the calculation by your own (but you need the newest 0.17 dev-snapshot from git).
Load FC-file, doubleclick on "Analysis" im model-tree, the FEM-wb activates.
Doubleclick on FEMMeshGmsh in tree, hit apply-button in dialog.
Click on CalculiXccxTools in tree, press solver button, write inp-file, press run.
When calculation finished, doubleclick on results in tree open result dialog.
File with cleared mesh:
- solver.JPG (7.88 KiB) Viewed 771 times
- frameFEM001.JPG (255.67 KiB) Viewed 771 times
- von_Mises_Stress.JPG (76.57 KiB) Viewed 771 times
