Automatic Light Gauge Steel Frame Creator And Panelizer macro
thschrader
Re: Automatic Light Gauge Steel Frame Creator macro
Postby thschrader » Sat Jan 06, 2018 12:23 am
Hi Humberto,
from a construction point of view you are right, but there is a problem with FEM.
Please see the two examples:
In case A there is absolutely no gap between the horizontal/vertical beam.
You get a compliant mesh, that means the structure reacts under loading as one body.
In case 2 there is a tiny gap (0,1 mm) between the bodies. You get a noncompliant mesh,
in fact two bodies. The horizontal beam deflects into the column. You can eliminate this
behaviour by running a contact analysis. For that you must know where all gaps are located.
A better way: eleminate all gaps.
hhassey
Postby hhassey » Sat Jan 06, 2018 12:50 am
Hi Humberto,
I know exactly what you are saying, I have dealt with this so many times.
as of now, the steel posts are smaller by exactly the thickness of the track, I made this to you get pretty drawings of the sections, and better renders. It should not be so difficult to set a FEM switch that when chosen it draws the tracks and studs with the exactly same dimension and thus overlapping, fusing such a piece should be no problem.
What are your thoughts?
paullee
Re: [EDIT] Re: Automatic Steel Frame Creator macro
Postby paullee » Sat Jan 06, 2018 7:41 am
hhassey wrote:
Tue Jan 02, 2018 11:35 pm
This error that was reported has been fixed !!!
paullee wrote:
Mon Jan 01, 2018 11:59 am
  File "/run/media/paullee/80G_Data/FreeCAD_Macro/FreeCAD_Hhassey/FreeCAD-Steel_Frame-master-942ec7a62468a731fc893daf6f5ebc268bdc9e43/Steel_Frame_Creator_to Macro.FCMacro", line 321, in onChanged
    vt=a.Shape.Volume
<type 'exceptions.RuntimeError'>: shape is invalid
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
    vt=a.Shape.Volume
Error Fixed!! , please grab a copy of the new version on Gitlab https://gitlab.com/Oriond/FreeCAD-Steel_Frame.git
Seem a lot of development after a while :) Would further try, thanks.
In addition to my earlier suggestions, maybe later installation like conduits and junction box for electricity, plumbing pipes etc. would be incorporated in the wall!
thschrader
Postby thschrader » Sat Jan 06, 2018 11:31 am
Hi Humberto,
That is exactly what we need for FEM.
Another intersting addition would be:
Generate the 2d-lines (center of gravity of U-shapes) to get a 2-D model
for running a calculation with beam elements.
regards Thomas
thschrader
Postby thschrader » Sat Jan 06, 2018 12:45 pm
Allright, I can import the frame sketch into my commercial statics-program
via dxf. Filtering does not work properly, but basically it works.
As an engineer I would prefer a beam analisys instead 3-D-FEM.
If you have possible hinges in the frame it is far easier to model the hinges
with beams.
thschrader
Postby thschrader » Sat Jan 06, 2018 1:24 pm
bernd
Postby bernd » Sat Jan 06, 2018 2:00 pm
in FreeCAD Arch is some tool to define the analytical axis of a Arch Structure.
thschrader
Postby thschrader » Sat Jan 06, 2018 4:56 pm
Hi Bernd, do you mean the axis-tools?
@Humberto:
I found a way to import complex sketches/wires into my statics-program without errors.
Even B-splines are accepted...
Creating the sketches and importing goes fast. I think there is no need to waste time
on programming a sketch-generator in your macro. In "normal" building-construction it doesnt
matter when the static-system has a little difference to the real geometry.
regards Thomas
bernd
Postby bernd » Sat Jan 06, 2018 5:18 pm
no much more smarter, in Arch_Structure the Structural nodes.
thschrader
Postby thschrader » Sat Jan 06, 2018 6:31 pm
Aaah..structural nodes. Yes, know I remember Yoriks thread:
https://forum.freecadweb.org/viewtopic.php?f=23&t=17909
@Humberto, an idea:
Can you define each member of the frame as a structure and after
that merge all parts together? When upgradung the frame to a structure,
I get only one structural point, but no lines.
When importing two beam-structures in arch-wb and do the fusion command
in part wb, the structural nodes/lines remain. And it is fully parametric.
Thomas
