a window object /MSAAx2, nvidia gtx760, win10/
Whats wrong with faceting?
cheers,
Re: Whats wrong with faceting?
Yes that problem is know since quite some time, it affects objects with different transparency values. So far I have been unable to find a solution...
Which OpenGL standard/version is being utilised in FC /in experimental options?/ ? ;
Would it be possible w/out devastating the current code to enable real time preview parameter/numeric changes in 3D view simultaneously ?
/I mean eg: change wall height in parameter field and the wall in 3D view changes simultaneously ??
cheers,
Is there a ticket for this issue?
It affect Part Compound with different transparency. Some other examples discussed below for information:
https://forum.freecadweb.org/viewtopic. ... 10#p172018
