BIM Workbench
yorik
Founder
Re: BIM Workbench
Post by yorik »
carlopav wrote: Sun Jan 06, 2019 6:55 pm What misleaded me about building parts and levels is that the icon in the tree was slightly different :)
Yes and I'm still not totally happy with this icon... :|
carlopav
Re: BIM Workbench
Post by carlopav »
yorik wrote: Mon Jan 07, 2019 12:54 pm
I could think about it maybe...
bitacovir
Re: BIM Workbench
Post by bitacovir »
Hi. Since some days ago the Addon Manager keeps updating the BIM module without stopping.
Version: 0.18.15656 (Git)
Hash: a60b6957db228c42a00a1e002a415cbb8309d3c8
Python version: 2.7.14
OCC version: 7.2.0
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
bitacovir
Re: BIM Workbench
Post by bitacovir »
bitacovir wrote: Tue Jan 22, 2019 12:57 pm Hi. Since some days ago the Addon Manager keeps updating the BIM module without stopping.
Fixed. I just manually deleted all BIM folders in AppData and reinstalled them with Addon Manager. Now it updates normally.
::bitacovir::
yorik
Founder
Re: BIM Workbench
Post by yorik »
No problem for me... Thinking about your other bug in another thread, is it possible that you have the BIM WB installed twice?
*EDIT* I had missed your reply. Great!
egv
Re: BIM Workbench
Post by egv »
Hi, I am starting to use this tool. thanks for the work !!
I would like to ask a question, sorry if it is duplicated, I could not find it on the site.
Every time I start the BIM WB I got the error message:
"Workbench failure: "module" object has no attribute "addDocumentObserver"
I also installed it on Mac and got the same error.
Thanks.
Cheers,
Enrique
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
OCC version: 7.2.0
yorik
Founder
Re: BIM Workbench
Post by yorik »
Indeed some latest code is only working on 0.18... I just added a switch that disable that functionality on 0.17. Try updating the BIM workbench, it should work now
egv
Re: BIM Workbench
Post by egv »
Did work !!
Thanks
Have a nice day.
didu
Re: BIM Workbench
Post by didu »
Hi to all
I kindly ask if I'm doing a mistake when I draw a steel structure using the Arch Structure tool or there is a bug in Freecad. If I use steel profiles for columns (IPE or any kind of those which are available in the library) it correctly works, when I draw a beam, something strange happens: with rectangular sections the beam is correctly modelled from a first point to the second while a steel profile beam appears as a column (vertical and not horizontal) placed in the starting point. I've discovered that in this tutorial the steel beam was differently modelled; is it the only way using the Arch Structure Tool or have I made something wrong?
Thanking in advance for your answer
Happy Easter to everyone
yorik
Founder
Re: BIM Workbench
Post by yorik »
I just stumbled on this problem too, drawing beams seems a bit broken... Will fix that ASAP!
